[IN] Chevy 408 w/AFR heads, G-body headers w/dual exhaust
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
For Sale Small Block Chevy 400. This is a 2 bolt 509 casting. The block has been bored .040 over and decked. It has sealed powered hyper pistons with a coated skirt (-6 cc). The rods (stock length) have been prepped with ARP rod bolts. Also the crank was turned. A new melling oil pump was installed. A stock replacement Milodon oil pan was used with a 1 piece oil pan seal. Currently uses a Lunati Voodoo camshaft (262/268, 219/227@.050) with a comp cams 3 way timing set. For cylinder heads It has AFR 195CC aluminum heads (262 cfm@.500" lift). The heads have 74 cc chambers (drilled for steam holes) which together with the pistons and decked block make for 10.3:1 compression. The heads have 1.6 roller rockers installed. The engine is installed in a 1984 G-body (Monte Carlo, Regal, Cutlass) and the 1-5/8 long tube headers and 2-1/2" dual exhaust are for sale as well. The engine has only 3200 miles on it. Nothing wrong with it and is still in the car running. Cold oil psi is almost 60 while hot is 30. I will also sell the Holley Stealthram intake manifold that is installed with fuel rails and fuel injectors. For the engine long block (no intake, pullies, exhaust, or valve covers) the price is $2500. If you want just the short block (no heads) I will sell that for $1500 and the AFR heads for $900. I will not seperate the block, heads, headers, intake, exhaust until the short block is sold. The headers are for sale for $125 and the exhaust is $100. The Holley Stealthram Fuel Injection intake w/30 lb injectors is for sale for $450. Buy everything and get a package deal. Remeber won't seperate until the shortblock is sold. If you are going with a carb I have a chrome air cleaner for sale.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
