Edge Racing Stall/Cam/Injectors/Intake and More
I have moved to Texas, these things are still in Mass. I can get the small things shipped out from Mass but the bigger things are pickup only.
Also Im willing to trade for a Ford 302 Carb Intake Manifold or Carb.
Brand New Lloyd Elliot LT1 Cam(Cam Card is included but I will only give out the info that was posted on the main page of his site). 232/240 .584/.584 108 LSA(close to a 306 cam with more lift, was originally a 300 dollar cam) -215 Shipped
30 Pound SVO Injectors. One Injector is missing the plastic piece that goes over the part that sprays. It covers metal and works 100% percent without it though. -125 Shipped
Ported and Descreened 3.5 inch LT1 F-body Maf sensor. -45 shipped
SLP Performance Thermostat 100224. Brand New in sealed bag. -20 shipped
Cloyes True Double Roller Timing Chain 9-3145. -55 shipped
Used LT1 Starter. -20 shipped
Used Stock LT1 Flexplate. No cracks or missing teeth. -20 shipped
Melling Performance Oil Pump Mel-10554. Brand New with oil pump driveshaft and a never opened GM white spring. -50 shipped
GM Performance Oil Pickup 12550042. New in Box. -18 shipped
I will not be able to ship these things below until I get back home. You are more than welcome to pick them up in Mass.
Stock LT1 Intake -50 Pickup Only (I could have a friend bring it to usps and have them box it but it would probably be an extra 15 +shipping for them to pack it.)
4l60E Transmission -175 Pickup Only
Competition Engineering Bolt-On Frame Connectors C3120 for a 3rd Gen Camaro(82-92) -110 Pickup Only
Used Iron LT1 Heads with stock springs/valves installed. - 30 Pickup Only
4th Gen Rear Axle 3.42 Gears. Still has calipers and rotors installed(rotors have surface rust, not sure how much life is left on them. I forgot to look before I left to texas.) - 225 Pickup Only.
Edge Racing "Street Edge LT / 4L60E", 3600 Stall. Brand new in box, never installed or used.(I have read that the late year model 700R4 use the same converters) -SOLD
Brand New in box Walboro 255 GCA758-2 lph in-tank fuel pump. -SOLD
Re: Edge Racing Stall/Cam/Injectors/Intake and More
Prices Lowered. Need this stuff gone within 2 weeks or it will just sit there for 6 months. I have pictures of everything, if you want to see anything just ask and Ill post it.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Need part # for stall.I might be able to use it for my build.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
How much for the 30lb injectors shipped to 72104?
The Edge Racing Convertor is a custom build so the part number won't help much. It fits any LT1 4L60E Transmission or late model 700R4 with the same spline count (should be 87 and up, the spline count should be 30).
Converter is sold.
Moving on Monday! Make an offer, if you want anything, need this stuff gone. Would like to sell at least the cam/injectors before I go, will let it go for a good price.
Car: 1987 Z28
Engine: LG4
Bump, I still have this stuff left. I also have the injectors back in my possession. Was gonna use them on my ford but going to go carb.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I would be interested in the LT1 starter. How much shipped to 12901?
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Do you have a picture of the injectors? I would be interested.
Thank you.
Lou
Thank you.
Lou
tmork454
Sep 29, 2015 06:33 PM
