[WI] Parting out 5 cars loots parts for sell
#101
Car: 92 firebird gta
Engine: L98 with minor mods.
Re: Parting out 5 cars loots parts for sell
I need a egr vac solinoid from a (87-92) with a tpi. how much to ship to va. 23602
#104
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
I need a v8 radiator for an automatic. Shipping would be to 42740.
#106
Car: 1989 Trans Am GTA
Engine: 5.7
Axle/Gears: 3.43
i need a oil pressure switch/sender for a tpi v8. also looking for plastic t tops
#113
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
you have any T-5 stuff? i need an electric speedo for mine
#116
Engine: 5.7
Axle/Gears: 3.43
got a maf sensor? modified mine to a 4 inch carbon fiber tube, then found out i would need to reprogram for it to read right. so on the shelf it goes till i get my chip burning stuff. shipped to 29906
#117
1 Post
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
im looking for an air cleaner hose from a TPI motor if you have one how much for it?
#120
1 Post
Car: 1990 Camaro RS
Its for a 1990 camaro. I know that this style of intake wasnt stock on my car im not sure what year of a camaro it was pulled from. the air hose thats in there now is jury rigged.
#121
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Do you happen to have a clutch fork boot for a V8 bellhousing in good condition? It is for an '89 Camaro.
#122
Car: 1987 Trans Am
Engine: 5.0 Liter
Do you have shorty headers or exhaust manifolds larger than stock for better gas mileage. Center cap for a 1987 r-16 wheel? Weather stripping for the doors? T-top interior headliner? Doesn't matter what color. I plan on replacing the looks of it. Dual exhaust parts? Drivers side set belt latch (goes between seat and hump)? All of this is needed for a 1987 Trans Am I just bought.
#124
1 Post
Car: 87gta 88gta 88marovert
#126
I need the front air dam for my camaro,87. Let me know cost with shipping to 71933
Also give me a price on a stock y-pipe. I'll know here in a few days if i'm gonna need one or not. Thanks
#127
1 Post
No good air dams right now I have a couple stock y pipes 25 + shipping. Sipping going to be around 25 to 50 depending on how fast you want it.
#128
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I'm looking for a 145mph speedo with or without bezel. If you have one, how much shipped to 49546?
#130
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
I'm looking for a few things to complete my swap from 305 tbi to 377 TPI.
-all throttle body cables (fuel, tranny, cruise)
-PCV tubing to the intake and throttle body
-EGR valve
-fuel lines from firewall to fuel rail
and TPI air intake ducting and filter housing
all shipped to K8H 2B4 in ontario Canada
PM me with a price
-EGR valve
PM me with a price
#133
1 Post
-EGR valve
PM me with a price
-EGR valve
PM me with a price
#134
Car: '64 Scout
Axle/Gears: HP 60 front, Eaton HO72 rear, 5.13
I'm looking for a throttle cable and pedal, and a 700r4 tv cable from a tpi car. Got one?
#136
Car: 1988 Trans Am GTA restoration proje
Engine: 5.7 TPI
Axle/Gears: 3:27
Looking for a high rise wing, white if possible.
shipped to Canada?
shipped to Canada?
#143
1 Post
#144
Car: '64 Scout
#145
Car: 1989 GTA White Hardtop
Axle/Gears: 9 bolt 3.27
I need the little plastic trim that goes on a firebird door panel where the latch and lock lever is. Believe it's called a door handle bezel and it is different than a regular firebird's. Mine is a 1989 GTA. I also need a good lower dash housing. That's prob not the correct term for it but it is the part between the upper dash and the console that holds the radio and heater controls. Let me know if you have any of this.
#146
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
any L69 parts?
heads and/or computer
#148
1 Post
#150
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Do u have the radio bezel for the firebird?
does it have any cracks?
How much shipped for 90602?
