[NY] chevy 350
Car: 92 camaro
Engine: V6
chevy 350
350 chevy 010 Block bored .30 over to make it a 355 with 1.6 Roller Rockers and Bang for the Buck Combo, Summit Stage 1 Intake, 750 cfm Q-jet, Cam/Lifter Kit Advertised Intake Duration: 282 Advertised Exhaust Duration: 282 Advertised Duration: 282 int./282 exh. Intake Duration at 050 inch Lift: 224 Intake Valve Lift with Factory Rocker Arm Ratio: 0.465 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in. Exhaust Duration at 050 inch Lift: 224 Lobe Separation (degrees): 114 Duration at 050 inch Lift: 224 int./224 exh. Valve Lift with Factory Rocker Arm Ratio: 0.465 int./0.465 exh. lift Tru-Roller Timing Set, rebuilt 700r4 transmission. $1000/obo engine is stilll in my 86 z28 so you can hear it run... i am also gutting the shell so if anyone needs other parts as well please contact me
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
