[MN] non-WC t-5 with clutch, flywheel, slave/master, etc
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
have a non world class T5 from an 84 camaro Z28. comes with a hays street/strip clutch with around 3000 miles on it, stock flywheel cut .060" with matching shim, the newer LS1 style slave/master combo with around 1500 miles on it, also have the 5 speed crossmember, torque arm, and driveshaft if you want it (driveshaft will need new U joint caps) tranny has a new energy suspention poly torque arm mount on it. i switched to a turbo 350 with spohn crossmember/torque arm and driveshaft and am tired of kicking this around the garage
the tranny will need work, but was driving fine when i took it out. was leaking fluid from the input shaft seal, i would suggest having it gone through just to make sure, as you should before putting any used transmission into a vehicle. sold 'as is'.
must be picked up in bemidji MN, will not ship this, but i will however meet you on the edge of town at a gas station or something similar with the tranny and help load if you want.
$350 - please email me at kawmerro@hotmail.com
Car: 1984 Z28
Re: non-WC t-5 with clutch, flywheel, slave/master, etc
i will also include a freshly rebuilt starter as well
monte87cortez
Sep 26, 2015 08:10 PM
