[MO] Fresh rebuilt 350 roller shortblock w hotcam
Located in Southwest Missouri. Built 355 SBC with no miles on her at all. 91 L98 block was used for the build. Block was tanked and baked, bored 030 over, and decked. Speed Pro Flat top pistons, moly rings. Eagle crank, rods, clevite bearings, . Melling Hi volume oil pump, LT4 Hotcam .525 .525 219/228, cloyes billet double roller timing set. Pro Street balancer. Fel Pro gaskets. That pretty well sums up the bottom end. All new high quality parts.
$800 I have more than this in just parts.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Fresh rebuilt 350 roller shortblock w hotcam
That's a nice deal! Some lucky dog better grab it!
Good luck with the sale.
W
W
Car: 1987 GTA
Transmission: 700R-4
Re: [MO] Fresh rebuilt 350 roller shortblock w hotcam
I'm interested but would like to know a little more info on the engine. Well first off why you selling it? Secondly did a shop rebuild it or did you personally? Also did you install the hot cam kit or did you peice together your own kit? Are you using roller rockers or the stock 1.5 stamped steel? I guess just tell me everything you can about it. I am within driving distance pretty much. I frequent omaha nebraska quite often which isnt to far depending where in missouri you are.
The motor was build by a SR ASE tech at Mayse Chevrolet in Aurora Missouri not myself. The LT4 Hotcam was purchased from Summit...just the cam not the kit. I bought 1.6 roller tip rockers to go with it from summit as well. They are summit branded rockers and are for sale here in a seperate thread. Im selling it because Im buying a LS1 that I got an insanely good deal on and need to sell this motor or the wife will murder me. All the machine work on the block was performed by Oreilly Auto parts machine shop in Springfield Missouri...which is where I am located.
Car: 1987 GTA
So i'm assuming the eagle crank and rods are just cast and the pistions hypereutectic?
Car: 1987 GTA
Well i think i may do an LS swap on my car possibly. So good luck with the sale. If anything changes with my plans i'll definately be getting back to you, thanks.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
$600 cash?!? Please get back to me
Very interested! You have a pm!
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
07-19-2009, 07:55 PM #9
? It says it's still for sale.
