Mostly complete TPI
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Mostly complete TPI
Up again is a complete 85-88 tpi setup.
I don't need these parts anymore, I've converted to carb so everything is up for grabs. If you just need the intake, plenum ect ect I have the egr, IAT, tps, knock sensor all of it to go along with it. I have a 305 ecm and can give the OBII hookups as well. The harness was cut, lockup wire, fan wires were cut to run a manual control. The one relay wire was cut and spliced with a better connector. Still didn't work on the car but the relays were ticking and the fuel pump wouldn't kick in might have been a bad connection on my car I also have the Dizz with just a rotor and a new mod chip installed, Put on a cap and its good to go.
I'd like to keep everything together, I know what these intakes go for and I am looking to get atleast close to what its worth.
If you have anything for my carb conversion like RPM air gap intake, fuel lines to mallory reg, or a vac advance dizzy let me know. I have a holley 650dp and Im also looking for a rebuild kit.
Shipping will be about 50bucks, this stuff is in the box and ready to go, It weighs about 65lbs if I remember correctly.
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
