[MD] moroso switch pannels / custom wiring harness with relays and custom dash
Car: 88 formula
Engine: 350 goin carb
here is something that i spent a lot of time wiring. all wires were cut as close to the part they were powering and clearly labeled. every thing worked perfectly. there is a harness clip behind each pannel so they can be removed just like your stock stuff. i used this to controll water pump,fuel pump, starter, 2 fans, lights, ignition, nitrous. it was wired so all the switches could be used while key was off BUT the starter i wired it so you would need a key to start.
(allows you to run water pump and fans in the pits to cool.
i am including in this:
5 switch pannel
http://www.summitracing.com/parts/MOR-74134/
2 switch pannel with start button
http://www.summitracing.com/parts/MOR-74130/
relay center
2 circut breakers
all fuses and wires.
i will even toss in the dash piece that has holes cut for 6 2 1/16" gauges and a tach.
$250 shipped ups ground
i am willing to part this out if i cannot sell with in two weeks.
last relay was for nitrous
5 switch pannel
relay center
2 circut breakers
