[NJ] 350 4bolt main and 700 r4 $600
Old Sep 7, 2009 | 10:05 PM
75nova's Avatar
Car: 94 blazer, 1985 berlinetta
Engine: 4.3, 5.7
Axle/Gears: 3.73 and soon to be 3.73 posi
I have a 350 4 bolt main motor (jasper rebuild?) complete from carb to pan. It is bolted to a 700r4 trans which has a b&m shift kit.
Motor and trans are still in car so you can see it run and drive if you are interested.
Engine has an oil leak at either the mechanical fuel pump, front crank seal, or timing cover. Seems to be in great shape otherwise.
roughly 80k miles on both.
will consider separating
will NOT consider shipping.
600 obo
Old Sep 7, 2009 | 10:26 PM
Da Spudro's Avatar
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Re: 350 4bolt main and 700 r4 $600
Where are you located at?
Old Sep 8, 2009 | 02:33 PM
75nova's Avatar
Engine: 4.3, 5.7
Im in mullica hill. Its about 20 minutes outside of philadelphia
Old Sep 8, 2009 | 03:41 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
how much for just motor? would you considering just selling block
Old Sep 8, 2009 | 08:26 PM
75nova's Avatar
Engine: 4.3, 5.7
I will take 400 for just the motor, 350 if I keep the distributor, carb, plug wires, and accessorys.
Old Sep 10, 2009 | 03:52 PM
75nova's Avatar
Engine: 4.3, 5.7
ttt
Old Sep 11, 2009 | 05:38 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
stock 350? how many miles?
Old Sep 11, 2009 | 07:07 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
any casting numbers? 1 piece rear main seal or 2?
any info on the build?
Old Sep 11, 2009 | 11:51 PM
75nova's Avatar
Engine: 4.3, 5.7
Its a stock 350 with about 80,xxx miles. Not sure if 1 or 2 peice rear main. I will grab the casting number tomorrow before I go to work
Old Sep 12, 2009 | 09:10 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
if you know what year it replaces should tell you 1 or 2 mostly 87 and up are 1 peice
Old Sep 13, 2009 | 01:08 PM
75nova's Avatar
Engine: 4.3, 5.7
the casting on the back of the block is 3970010. should be a 2 peice rear main. Mortec.com says 69-80. This was also the casting used for the dz 302 in the 1969 z28.
Old Sep 13, 2009 | 03:42 PM
75nova's Avatar
Engine: 4.3, 5.7
pic
Old Sep 14, 2009 | 11:23 PM
75nova's Avatar
Engine: 4.3, 5.7
500 for pair. need these gone
Old Sep 16, 2009 | 03:39 PM
75nova's Avatar
Engine: 4.3, 5.7
nobody wants to build a performance motor or swap out their old tired 305? MAKE AN OFFER!!!
Old Sep 18, 2009 | 08:02 PM
if it was a 1 pc rear main seal you wouldnt have it now, if you know of any i know alot of ppl who need em
aharvel50
Sep 21, 2015 07:31 PM
Ducati900ss
Sep 2, 2015 09:05 AM
DJanes97
Sep 1, 2015 02:55 PM
CamaroMike
Carburetors
Apr 15, 2001 11:11 PM
