[WV] Msd timing control for GM external coil
Old Sep 15, 2009 | 12:00 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Part number 8683 I think it's for 86 up gm cars and trucks with external coil. Timing can be retarded/advanced by up to 15 degrees. This was only used for a short time. Instructions included. $75 shipped except to some places where shipping would be slightly more.
Old Sep 16, 2009 | 11:11 PM
kaosanddoom's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7
Axle/Gears: 3.43
Re: Msd timing control for GM external coil
would like to get this from you. any thing you need on a trade? if not i will have to wait till i sell something i have listed here. let me know if we can work something out.
p.s. the stuff i have are a tpi setup, stock with out electronics, gta wheel and buttons and stereo from and 89, and a set of l98 heads, iron, with a brand new set of dual valve springs for high lift cams. springs are new in box still.
Old Sep 18, 2009 | 12:06 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Can't think of anything I need out of those.
Old Sep 20, 2009 | 10:25 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Bump $55 shipped
Old Dec 10, 2009 | 12:11 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Bump, still have. $40 shipped.
Old Dec 10, 2009 | 12:26 PM
Stephen's Avatar
Car: 87 GTA
How can a coil controller adjust timing? That should a function of the dizzy itself, not the coil.
Old Dec 10, 2009 | 01:50 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I am assuming it would just delay the signal from the cam trigger in the distributor before it fires the coil.
Old Dec 29, 2009 | 09:31 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Still for sale. No useless replies please. $25 shipped.
Old Dec 29, 2009 | 10:01 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
He cant help it. /the comments are always negative.
Old Dec 29, 2009 | 10:07 PM
Stephen's Avatar
Car: 87 GTA
How so?
I didn't even bother to point out that the cam trigger (comment by Will) is in the dizzy, and is a purely mechanical function, so it can't be changed.
I initially asked because I was genuinely interested. You've managed to twist a question into something else. Quit trying to stir stuff up.
Old Dec 30, 2009 | 08:21 AM
Originally Posted by Stephen
How so?
If your take my post literaly, I guess you would be correct. Here is more what I was meaning.
The signal goes from the magnetic pick up in the distributor through the Ignition module to the coil. The signal from the module is routed through the box and the box delays (or advances) firing the coil.
Old Dec 30, 2009 | 04:49 PM
bitchin86's Avatar
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
do you still have it?
9192camaro
16
Feb 3, 2019 12:21 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
L98GTA87
Aug 5, 2015 11:02 PM
