[PA] GTA Disc brake posi rear and others
Old Oct 19, 2009 | 10:53 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
I have a disc brake rear that was hit and the one tube is slightly bent. I was going to pull the calipers and mounts.
Is it worth pulling the carrier also? Is anyone local that might want the whole thing let me know soon, it's heading to the scrap bin!
I'm in York PA
Old Apr 24, 2010 | 08:12 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Re: GTA Disc brake posi rear and others
BUMP with revision
Old Apr 24, 2010 | 10:52 PM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
Im interested in the brake parts or the whole thing, pm me with how much you want for them, Im in lancaster so I can pick it up
Old Apr 26, 2010 | 05:20 PM
otecnick88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
I may be interested, I would just need the housing it's self for the brackets, brackets still in good shape?
Old Apr 26, 2010 | 05:25 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Yea, they are fine.
The disc (besides sufurace rust) look like they have a lot of life left in them.
Old Apr 26, 2010 | 05:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Delco-Moraine calipers or PBR's?
JamesC
Old Apr 26, 2010 | 05:51 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
JamesC
Pabst Blue Ribbion?
I'm not sure how to tell the difference? They have a 426 cast in them???
Old Apr 26, 2010 | 05:53 PM
Twin_Turbo's Avatar
Alu = PBR, both mounted trailing the axle
Delco Moraine = cast calipers, dr. side trailing, pass. side leading the axle.
Easiest way, if they rust they are delco moraine
Old Apr 26, 2010 | 05:57 PM
JamesC's Avatar
The PBR's would be much more desirable, IMO. Check my vbgarage for a pic (lower left).
JamesC
Old Apr 26, 2010 | 06:04 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Yea, It looks like Delco...but disc is better than drum
Old Apr 26, 2010 | 06:41 PM
Ok so how much for just the housing then?
Old Apr 26, 2010 | 07:37 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
No calipers or anything?
Old Apr 26, 2010 | 08:40 PM
Nope, noting just completly bare, no axles, gears, carrier, noting at all
Old Apr 26, 2010 | 09:12 PM
MWM's Avatar
MWM
Want a title? Post!
How much for just the backing plates? Mine are rusted and have two bolts that broke off in them. Cut the calipers off then broke off the other sides of the bolts too. Easy outs didn't work so I'm saying f it and getting new backing plates. Thanks.
Old Apr 26, 2010 | 09:15 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
You did read the left tube was bent?
Old Apr 26, 2010 | 09:17 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
I'd like to sell it as a set, stay tuned...
Old Apr 26, 2010 | 09:45 PM
Yes I did, just need the brackets auctually
Old Apr 27, 2010 | 04:54 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
You kind of lost me the brackets bolt to the tubes, so why would you want the stripped axle housing?
Old Apr 27, 2010 | 09:02 AM
I need like the supension brackets and such, I'm custom fitting a rear in and need the spring pearches, lca brackets, panhard brackts, all those goodies, see what I mean now? Don't matter it the tube is bent as long as those brackets/mounts are good
Old Apr 27, 2010 | 10:44 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Ok, so just the axle with the suspension brackets and NO brake brackets, $40?
Old Sep 14, 2010 | 08:47 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
any odds of you still having this?
I really want to switch from drums to discs
Old Sep 24, 2010 | 12:32 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
I'll take the carrier if you have it.
Old Sep 24, 2010 | 03:21 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Still have it. $75 +Shipping?
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
