WS6 sway bars $50 pickup only,Central Indiana
Re: WS6 sway bars $50 pickup only,Central Indiana
I do still have them. I will have to check the diameter of the rear bar tomorrow. I don't think I have all of the hardware. Pretty sure just the bars and the bushings and mounting brackets. I'll let you know tomorrow.
Thanks,
Brad
Thanks,
Brad
front bar measures about 1.418" (about 36.02mm) rear bar measures about .921" (about 23.4mm) Front bar has the bushings that go around the bar and the corresponding clamps and bolts. No end links. Rear bar has the same, bushings, clamps over bushings and clamps that go on axle (look like muffler clamps) but no bolts. No end links. The rear bar has a couple of arc marks on it where I was welding on a car on my trailer, ground was hooked to trailer, I laid this bar from the trailer to the car frame to ground it, resulting in the arcing. I think it's just fine, but that's up to you. You can call me at 317-370-3899
Thanks,
Brad
Thanks,
Brad
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
If you change your mind on shipping, let me know.
TMZIrocZ350
Oct 7, 2015 12:09 PM
