[NC] 0411 SBC swap harness
Car: 91 Trans Am
This is a bare bones LS1 PCM swap harness for a SBC. That means no AC, Emissions or anything else that isnt critical for running. Ideal for drag cars
VSS connector has amble length for a differential mounted sensor
Built around a LT1 intake but has ample length for TPI and HSR
Currently has the newer style TPS and IAC connectors for a LT1 throttle body. I can swap these for the old style no problem
PM me if interested but want changes or a separate harness repaired/built
edit:
No interest so I converted this to a stand alone LS1 harness
edit:
Car: 91 Trans Am
Re: 0411 SBC swap harness
Yes it is designed specifically for the GEN I SBC
Price is posted. Use any 99+ LS1 PCM. Most popular is the 0411 PCM that was used on nearly every GM vehicle 01-02
Car: 91 Trans Am
Bottom price is posted and its not moving. These harnesses take 10-16 hours to build, not counting the research and time spent drawing diagrams or collecting connectors
Fast355
Dec 2, 2016 06:33 PM
