[AB] Weiand 8120 intake--NIB +shifter and gauges
Old Nov 5, 2009 | 10:55 AM
Tommychu's Avatar
Calgary, Alberta
There will be more to come, but I have a new in box weiand intake I'll let go for $100 obo.
I have a B&M Shifter and a covan's gauge panel with Sport Comp gauges but those two are in the car and I'm not sure when I'll take them out. if someone is interested in either let me know. PM me for pictures.
Old Nov 5, 2009 | 12:54 PM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
Re: Weiand 8120 intake--NIB +shifter and gauges
what is the shifter exactly? and is it mounted to a 700r4 (4-speed)? thanks!
Old Nov 5, 2009 | 07:50 PM
Tommychu's Avatar
It's the B&M direct fit console MegaShifter for the third gen. Part number 80692. It's set up for a 700r4 right now but it'll work for a 3 speed, I think there's just a pin you have to switch around. The handle is a bit scratched because I used to take it off when I parked it for security, but I have the means to remove the scratches and re-polish it. I'll also include the stock plastic plate- when installing it you have to cut it out in a few spots and put B&M's plate on top of it, which is a real PITA.
Old Nov 5, 2009 | 08:59 PM
S_Johnson's Avatar
Car: 87 T/A
Great! I have a 700R4, what's your price shipped to 98531 US? (Washinton State). Thanks
Old Nov 9, 2009 | 09:35 PM
Tommychu's Avatar
PM Sent
Old Dec 1, 2009 | 10:19 AM
Tommychu's Avatar
Shifter sold.
Gauges and intake still available.
I also have an 83 trans am posi/disc brake rear end, sway bar included, and NIB pads/rotors/calipers/e-brake cables for it. pretty sure the ratio is 3.42. got it from a junkyard so the diff cover is punched but internals should be fine. haven't looked inside yet, I will do that and replace the cover if someone is interested. posi is still very tight. I can ship this but the closer you are to western canada the better. PM for more info.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
JSDaddy189
Sep 26, 2015 03:50 PM
