[VA] headers long tubes and shortys heads many parts....
Old Nov 23, 2009 | 12:19 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
well hopefully in the next couple weeks ill be striping down my 82 trans am and will be selling some of my goodies to fund my 5.3 turbo project for my 86. ive got tons more engine parts/3rdgen parts so ask if its not listed and i may have it.
hedman longtubes ball socket normal painted header rust. $50
hooker shortys normal rust $50+ FREE y pipe if wanted
882 heads need rebuilt $100
416 heads need rebuilt $100
comp 268xfi cam never ran but was installed in new condition with new lifters and cam card! $130
stock th350 tq converter $30
86 back glass with third brake light and defroster + wrap around decklid $100
le9 (truck) 305 block $50
305 bored .030 summit 1103 cam 1.6rr shaved 416 heads about 5k on motor runs well with right stall gears + traction should run 13s $700 obo
pair of power doors painted white $100
have two stock aluminum q-jet intakes painted black $40each
custom y for hedman longtubes and single 3.5 exhaust with cutout and stock ls1 muffler decent shape it does what its ment to do not prettiest welds but $150 for it all or $100 for just y with cutout. y fits ball socket headers
pair of 26 spline axles $50
some of these parts still need removed from car like the longtubes and the motor! i will try to get pictures as soon as i can upon request email works best for me since i get it directly to my phone.
got_viper_2000@hotmail.com
im willing to do some trades but only looking for gen III stuff like ls1/ls6 styles intakes t70-76 turbo cams ect....
Old Nov 23, 2009 | 01:06 AM
Boosted1.9's Avatar
Car: 06 Corolla
Engine: 1zz-FE 1.93L lol
Transmission: c59
Axle/Gears: fwd ftl
Re: headers long tubes and shortys heads many parts....
Ill take longtube headers, can email me at
bflee87@gmail.com
Old Nov 23, 2009 | 01:43 AM
Screamin86's Avatar
alright ill let ya know when i get them off wich i hope will be soon! im dd the car until my yukon is back from the paint shop!
Old Nov 23, 2009 | 08:32 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
For the shortys what part# are they and you got any pics?
Old Nov 23, 2009 | 10:57 PM
T-rock's Avatar
Car: 1987 camaro iroc
Transmission: 5 speed borg warner
Axle/Gears: 3.45
I sent you an email,i ll take the cam and lifters. atonyroc@aol.com Thanks.Troc
Old Nov 23, 2009 | 11:03 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am interested in the headers if they have the air pipes on them and i will also take the y pipe also would the cam work with a tbi if it does i will take it
Old Nov 23, 2009 | 11:58 PM
Screamin86's Avatar
the cam is a flat tappet cam
Brand COMP Cams
Manufacturer's Part Number 12-366-4
Part Type Camshafts
Product Line COMP Cams Xtreme Fuel Injected Camshafts
Summit Racing Part Number CCA-12-366-4
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,000-6,000
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 231
Duration at 050 inch Lift 224 int./231 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 280
Advertised Duration 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.515 in.
Valve Lift with Factory Rocker Arm Ratio 0.520 int./0.515 exh. lift
Lobe Separation (degrees) 113
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible Yes
Grind Number 268XFI H13
Quantity Sold individually.
Notes Requires exhaust upgrade, larger fuel injector, intake manifold plenum, and aftermarket computer chip.
the shortys do not have air pipes and are also painted style headers the y pipe is one that was made by the cars previous owner so it is not the hooker y. i will get pictures of everything tomarrow.
Old Nov 24, 2009 | 12:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
But does the y pipe bolt on to the headers i will still take them
Old Nov 24, 2009 | 04:39 PM
Screamin86's Avatar
Yes it does bolt up! I didnt make it to my storage unit today but will do my best in the morning!
Old Nov 25, 2009 | 10:13 AM
killa66cam's Avatar
Do you have a part number for the long tubes...or can you tell me the sizes?
Cam
Old Nov 25, 2009 | 12:25 PM
Screamin86's Avatar
this is from summit site.
Brand Hedman Hedders
Manufacturer's Part Number 68460
Part Type Headers
Product Line Hedman Street Hedders
Summit Racing Part Number HED-68460
Header Style Full-length
Header Material Steel
Header Finish Painted
Primary Tube Diameter (in) 1 5/8 in.
Collector Attachment Ball and socket flange
Collector Diameter 3.000 in.
Tuned No
Primary Tube Gauge 18-gauge
Flange Style Standard
Flange Thickness (in) 1/4 in.
Bolts/Studs Included Yes
Gaskets Included Yes
Reducers Included Yes
Y-Pipe Included No
Motor Mounts Included No
Transmission Mount Included No
Quantity Sold as a pair.
Old Nov 25, 2009 | 01:45 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok once you get the pics pm me
Old Nov 26, 2009 | 12:02 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Who made the ypipe? email me at brokenrider226 with pics pleace
Old Nov 28, 2009 | 06:02 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
PM sent
Old Nov 30, 2009 | 01:42 PM
Screamin86's Avatar
sorry so long but with thanksgiving and trying to get my pickup and yukon back on the road ive been busy. here are some pics of the shortys with y pipe.
Old Nov 30, 2009 | 03:50 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
How much would it be for the headers and y pipe shipped to 90650 and whats the size of the y pipe exit
Old Nov 30, 2009 | 04:37 PM
Screamin86's Avatar
I believe its 2 1/4 it may be 2 1/2 ill check tomarrow
Old Dec 29, 2009 | 04:59 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Do you have the long tube headers still?
Old Dec 29, 2009 | 09:26 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Did you ever check
Old Jan 2, 2010 | 03:47 AM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
do you still have the headers either long tube or shorty??? im very interested
Old Jan 3, 2010 | 10:44 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
can you post pics of the other exhaust parts? or what isn't already sold thanks
Old Jan 7, 2010 | 12:40 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
pics and shipping to 52732 on longtubes
Old Jan 19, 2010 | 06:46 PM
Transamthunder's Avatar
really interested on them shorties
Old Jan 19, 2010 | 11:46 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Those shorties sold yet? Im also interested. PM me a shipping quote to V9B5W2, BC Canada if you still have them. Thanks.
Old Jan 20, 2010 | 09:45 AM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
i'm interested in the shortys too. shipping to 29010..
Old Feb 6, 2010 | 09:03 PM
Screamin86's Avatar
ive been meaning to post something but because of the crazy weather we've had in my area this winter i have not been able to touch the car to start striping it. im hoping as soon as the weather warms up and all the snow melts im going to try to pull it all apart one weekend. again im sorry about the delays but i never expected such a winter that we have had.
Old Feb 6, 2010 | 10:44 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
has anything been sold? Do you still have the shorty headers and y pipe? seem to be allot of interest in those and if they aren't still interested I am
Old Feb 7, 2010 | 05:24 PM
Screamin86's Avatar
they are pending sale atm
Old Feb 7, 2010 | 08:04 PM
jcline07's Avatar
Car: 1984 camaro
Engine: 305 l69
Axle/Gears: 3:08
dude ill take the shortys and y pipe if ya still have them. shipping to 76108? hope ya still got them!
Jason
Old Feb 23, 2010 | 07:40 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
would you sell the cutout alone? if so is it a electric one and how much shipped to 48220?
Old Feb 23, 2010 | 08:42 PM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
Still have the long tubes, or are they still on the car? If you still have them pm me with shipping to 40965 and pics. Thanks, I have a payment ready.
Old Mar 13, 2010 | 02:20 AM
mcguffey4's Avatar
Car: 1991 Chevy Camaro RS Convertible
Engine: 5.O/305
Transmission: Automatic
do you still have headers
Old Mar 22, 2010 | 11:38 PM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
looking for a stock or ported Plenum, I don't need the TB.
Old Mar 24, 2010 | 12:57 AM
jersyboyy's Avatar
Car: 85 Camaro
Pm me bottom dollar Price shipped to 27529 on longtubes with custom ypipe and catback MONEY IN HAND!
Old Mar 29, 2010 | 10:51 PM
jersyboyy's Avatar
Car: 85 Camaro
POm me bottom dollar on just ypipe shipped to 27529
Old Mar 29, 2010 | 11:00 PM
ncmail's Avatar
Car: 89 FireBird
Transmission: AUTO
shortys still available?
Old Aug 26, 2010 | 07:38 PM
AMERICAN METAL's Avatar
Car: 1989 Camaro iroc-z
Engine: 355, patriot 190cc, comp 280h
Transmission: 700r4, 3k tall, tci constant press
Axle/Gears: 10 bolt /4.10 GM POSI
Do you still have the long tubes?
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LilHot
Aug 23, 2015 09:36 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
