383 Stroker with Dart Heads TBI For Sale
I put this motor in my truck about three years ago. It only has about ten thousand miles since new, truck was not a daily driver. I came across a great deal on a 04GTO LS1 T56 combo and I am in the process of installing that now. This motor was proffessionally built and runs perfect.
Four bolt one piece rear main seal
Internally balanced 383 crank
9 to 1 compression hyperutectic
Dart 165 heads
214 at .050 duration with .472 lift int. and exh.
Edelbrock TBI intake
Comes with chrome oil pan and valve covers, some small areas of surface rust, water pump is HD, and I have the flexplate as well.
I paid $3000 for it, asking $1200.
I am in Orlando, FL
I could pull the wheels off the engine cradle and bolt it to a pallet for shipping if neccessary.
Dart 165 heads
I am in Orlando, FL
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Re: 383 Stroker with Dart Heads TBI For Sale
what's it putting out?
have u had it on a dyno?
The motor was built to work in a 4200 lb truck so hp is probably only 330 but torque is somewhere around 400lbft. Revs good to 5700 rpm and would smoke the tires easily.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
PM sent.
mhatfield 14
Oct 24, 2015 07:48 AM
LT1Formula
Aug 20, 2015 09:36 PM
