[WI] shaved brake drums off 84 less than 7lbs each
Old Jan 24, 2010 | 07:22 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
here are a set of good drums I had machined down. I was running them on a 10 bolt. they weigh under 7 lbs stock they weigh 15lbs. they say 10 pounds off the rotationg mass is the same as 100 pounds off the car. I went to ford 9 with disk brakes no need for these
$120
Old Jan 24, 2010 | 11:23 PM
robert1's Avatar
Re: shaved break drums off 84 less than 7lbs each
Just so I'm clear, $120 for two machined stock iron rear brake drums? Or am I missing something?
Old Jan 24, 2010 | 11:55 PM
Car: 84
Re: shaved brake drums off 84 less than 7lbs each
Yes I have 2 shaved rear brake drums off a 1984 camaro with the stock 10 bolt. The whole outside of the drum is gone so the drums alittle under a 1cm thick. I put about 300 miles on them over the street and racing. I noticed the engine reves faster in gear with them. Im going to a ford 9 now
I would like $120+ shipping for them.
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
