(TX)complete tpi system,wiring,ecm,L98 heads
Car: 1989 GTA
Engine: pending install 383 tpi
Just like it states I have a 350tpi motor with the 9th injector, throttle body, wiring harness from an 89, so it has the extra box from the fenderwell, and a set of L98 heads prices are as follows pictures could be up as early as tomorrow just give me time. This was a running motor just looking to sell the topend
heads with valve covers 250
TPI intake with throttle body and 350 22#injectors 225
wiring with ecu 100
I also have the accessory brackets, distributor, a/c compressor,cam shaft just throw out offers on that stuff
stock WS6 pan hard bar 15
I am willing to separate if noone wants this stuff together just send a PM
all prices are best offer also willing to trade parts I can use to build this motor up,rods, pistons, cams ect might be considering going carbed so you can PM me those parts also
wiring with ecu 100
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
Re: (TX)complete tpi system,wiring,ecm,L98 heads
i've been looking to go the opposite way. I got a carbed 400sbc, edelbrock torker 2 intake, and edelbrock 750 carb. do you think ur setup would be ideal for me. could it handle the 400? if not do you know where i can get something like this? kinda on a budget.
Car: 1989 GTA
I would say no to handling the 400. I know that the TPI system does really well on stock 305/350 but even 383 have to go aftermarket to really breath, not saying it hasnt been done but with 400ci I'd say thats would make it more of a towing motor. Besides I do not even know if it will fit on a 400
Car: 1989 GTA
whats your times in the 1/4 mile with your setup?
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
sorry, havent had it down the track. i just swapped it in not too long ago and still tweeking the drive train a bit.
Terrell351
Jun 13, 2021 01:13 PM
beachrodder
Aug 25, 2015 08:05 AM
