delete
Old Feb 13, 2010 | 03:34 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
delete
this post is dead
Old Feb 13, 2010 | 03:40 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: complete Vortec Stealth Ram setup, 58mm TB, 1.6 rockers,
pics
Attached Thumbnails delete-img_4608.jpg   delete-img_4607.jpg   delete-img_4606.jpg
Old Feb 13, 2010 | 03:45 PM
Car: 1989 IROC-Z
Engine: 346 LS6
more
Attached Thumbnails delete-img_4605.jpg   delete-img_4603.jpg   delete-img_4602.jpg
Old Feb 13, 2010 | 03:47 PM
Car: 1989 IROC-Z
Engine: 346 LS6
and more
Attached Thumbnails delete-img_4599.jpg   delete-img_4596.jpg   delete-img_4594.jpg
Old Feb 13, 2010 | 03:51 PM
Car: 1989 IROC-Z
Engine: 346 LS6
more
Attached Thumbnails delete-img_4593.jpg   delete-img_4592.jpg   delete-img_4589.jpg
Old Feb 13, 2010 | 03:55 PM
Car: 1989 IROC-Z
Engine: 346 LS6
and even more.. email me if you was want pics of anything else.. ill get pics of the rockers up too
Attached Thumbnails delete-img_4588.jpg   delete-img_4535.jpg   delete-img_4527.jpg
Old Feb 13, 2010 | 03:58 PM
Car: 1989 IROC-Z
Engine: 346 LS6
picss
Attached Thumbnails delete-img_4511.jpg   delete-img_4494.jpg   delete-img_4488.jpg
Old Feb 14, 2010 | 12:05 PM
Car: 1989 IROC-Z
Engine: 346 LS6
rockers
Old Feb 14, 2010 | 01:38 PM
bvahnee's Avatar
Forgive me I dont know much about this setup, but is the ECU included? You mention a chip, but is the ECU and wiring all separate, or does this use the factory TPI ECU and wire harness? Im currently running vortec heads with a holley 770, but I would love to have EFI. If all I need is the little bits you mentioned and an ECU/Wire harness from a TPI setup then I will get back to you soon, the price seems very fair. Thanks.
Old Feb 14, 2010 | 07:47 PM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
are the rockers self aligning?
Old Feb 14, 2010 | 08:01 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Looking at the pic above they are not
Old Feb 15, 2010 | 10:33 AM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
very interested. but i dont know much about efi. will it just bolt right up and plug in to my old tpi set up? what would i need to change or modify? i know i need vortec heads.
Old Feb 15, 2010 | 02:53 PM
Car: 1989 IROC-Z
Engine: 346 LS6
rockers need guideplates
when you tune tpi's the easy way to to burn chips.. i will provide a starter tune on a chip.. you need an adapter.. and they are only around 35 bucks that allows you to put the chip in the ecm... This setup is for a 1989 5.7 tpi harness... currently the harness is not included becuase i will need a few connectors for things like fan switch and maybe a few relays.
heres a link to the chip adapter for the ecm
http://www.moates.net/product_info.p...products_id=32
to answer your question yes to put this in another car that didnt have tpi you will need a 1989 tpi harness and ecm... my setup and tune [chip].
ill include the ecm, with adapter and the chip.. then you would only need the harness and sensors for another $100... my computer worked well... no glitches. it was remanufactered once however before i bought the car. so is age is newer than 1989.
Old Feb 16, 2010 | 08:50 AM
Car: 1989 IROC-Z
Engine: 346 LS6
ill ship the rockers for $200 to the 48 come with locks!! barely used
other sensors ill throw in with the setup are
02 sensor.. bought new gm.. 3000 miles
knock sensor.. bought new gm.. 3000 miles
MAT
throttle body comes with iac and tps
other sensosr you need are fan switch coolant temp, oil pressure, maf
ill throw the computer in with the deal.. $900 .. theres alot of good stuff there... i was running this setup as a daily driver. i had no issues at all with it
Old Mar 18, 2010 | 06:20 PM
cshabby's Avatar
Car: 86 IROC-Z
Transmission: R4
do u still have this intake? thx
Old Mar 18, 2010 | 08:24 PM
Car: 1989 IROC-Z
Engine: 346 LS6
no
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
