parting out 1986 iroc-z--tpi
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: 700-R4
Re: parting out 1986 iroc-z--tpi
Do u have the gauges and if so how much for them shipped to 45323???? and also may u PM me pics thanks
and is the front bumper and ground effects in good condition thanks
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: 89 iroc-z
Engine: 5.7 tpi
Transmission: soon to be t56
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
How many miles were on this car? Would you trust the tranny to be ok, and did you actually drive the car? I can pick up, let me know if it's good still and if so, how much.
Car: 86 Iroc
Axle/Gears: GU5 323
Looking for breather tube that goes from throttle body ( pass side ) runs along valve cover and then into valve cover? Ship to 02817?
Car: '90 RS Convertible
Engine: 305 TBI
Have you got a good lower air deflector - the plastic piece under the car that directs air up into the radiator?
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
once again it was great doing business with you BUMP for awesome guy to deal with
i have a 87 formula 350 i'm stripping now that has 108,000 miles. ,tranny shifts fine. $150 picked up
Car: 89 iroc-z
Engine: 5.7 tpi
Car: 2001 Camaro SS
Engine: LS6
Axle/Gears: 4.10
Car: 90 Iroc-z tune port 350 mod
Engine: TPI 350 chipedout neck breaker tran
Transmission: 700R4 built
Axle/Gears: 7.5 10 bolt rear end
what all do you have left of the car would like t have waht left if you have a title
Car: 89 Iroc
any chance you still have a cold start injector? the 9th injector on the drivers side that leads to the fuel rail? or have you sold all of that?
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Do you still have the distributor? Could anyone confirm this is the correct distributor also for an '86 carb engine? Harness looks the same.
If so, shipped to 17847?
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
