[PA] TPI w/ porting and SLP setup, T5 swap parts, SLP y-pipe, others
Old Apr 10, 2010 | 05:11 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Got rid of the Firebird, now need to sell leftover parts...
Some pics are below, additional available upon request. If you have a specific pic request, let me know.
First up- TPI setup with cool parts.
Stock plenum, ported to match SLP runners (also ported inside the entry)- $50 (I do have the plate for over the distributor)
Stock TB with airfoil- $50
Stock base, matched to runners only- $50
SLP "siamesed" runners, transitions smoothed for better flow- $250
Stock fuel rails- $10
MAP sensor- $10
New EGR (5k miles)- $10 or free with base
Accel 24 lb. injectors (5k miles)- $100
Everything worked great on the car. Made real good power. When I sold the car, the guy didn't want the engine, so I got it all back. Note: Only the TPI setup is for sale, not the whole engine or anything else from it.
$400 for the whole setup, plus shipping (this is heavy and large)
Factory LS1 injectors- 24lb., VERY low miles (under 500)- set of 8- $130 shipped
They are shown at this link.
Parts to complete a T5 swap into an auto car- almost a complete kit
NEW Luk clutch- $100
Bellhousing- cleaned and painted- $25
Flywheel- this is the lighter one!- $50
NEW GM clutch cylinder setup (master and slave)- $25 SOLD!!!
NEW GM lower shift boot- $10
NEW clutch switch- $5
NEW GM clutch fork and pivot ball- $20
NEW Hurst shifter- $100
NEW custom upper shifter boot- red and grey leather- $10
$225 for all, plus shipping (this is sorta heavy and awkward size)
Sorry, I know I have the pedals and the center console panel somewhere, but I can't find them... Trans is NOT included.
NEW stainless SLP Y-pipe for L98 car- $125 plus shipping (light but LARGE box)
Stock TPI parts- all stock, and dirty
Plenum- $50
Runners- $25
Base- $50
Or $100 for all- NO HARDWARE or any other parts
Two REAR 16" "fiero style" Firebird wheels
Were painted white, I started stripping one
Good for drag tires...
$50 for the pair plus shipping
All items located in SE PA, so pickup is welcome.
?-90 Firebird front park light housings-both-not broken- $10 plus shipping
Attached Thumbnails TPI w/ porting and SLP setup, T5 swap parts, SLP y-pipe, others-runners.jpg   TPI w/ porting and SLP setup, T5 swap parts, SLP y-pipe, others-tpisetup2.jpg   TPI w/ porting and SLP setup, T5 swap parts, SLP y-pipe, others-ypipe.jpg
Old Apr 11, 2010 | 11:35 AM
twistedz28's Avatar
Car: 1991 1LE CAMARO
Engine: L98/355cu
Transmission: WCT5/for now
Axle/Gears: 9 inch ford/ detroit locker
Re: TPI w/ porting and SLP setup, T5 swap parts, SLP y-pipe, others
can you tell me what kind of t5 you have?
Old Apr 11, 2010 | 02:53 PM
mmyers_417's Avatar
Car: 88 formula; 06 cobalt ss
Engine: 305 tpi; 2.4 ecotec
Transmission: WC T-5; F23
Axle/Gears: 3.45 posi; 3.84
would you be willing to sell just the slp runners and plenum or do u wanna keep it a package i live 15min across the bridge in jersey so local pickup shouldnt be a problem
Old Apr 11, 2010 | 03:20 PM
twistedz28's Avatar
Engine: L98/355cu
sorry I thought you had the trans too I didn't read carefully enough.
Old Apr 11, 2010 | 03:57 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
i am also intersted in the runners, would you lemt me got those?
Old Apr 11, 2010 | 06:29 PM
SCCAjunkie's Avatar
Car: 84 Z28
Twisted- the T5 is NOT included at this time, but may be for sale later. I'm not sure if it's going to be used for another project at this point.
As far as separating the runners- I have one person who asked fist about the whole package. Should that fall through, I *may* consider splitting it up. If that is the case, I will post here.
Old Apr 11, 2010 | 06:45 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
What about seperating the Hurst shifter?
Old Apr 11, 2010 | 06:51 PM
SCCAjunkie's Avatar
Car: 84 Z28
PM me with an offer.
Old Apr 12, 2010 | 07:26 AM
mmyers_417's Avatar
ok let me know bc i have a vortec heads so i cant use the base anyway
Old Apr 17, 2010 | 04:49 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
interested in the y-pipe, but is it for a 350 car or 305 car?
Old Apr 17, 2010 | 10:54 AM
SCCAjunkie's Avatar
Car: 84 Z28
I bought it for a 350, but I thought it would fit both...
Old Apr 17, 2010 | 11:00 AM
SCCAjunkie's Avatar
Car: 84 Z28
Separate prices have been listed for all parts.
Old Apr 18, 2010 | 08:02 PM
SCCAjunkie's Avatar
Car: 84 Z28
Added LS1 injectors.
Old Apr 18, 2010 | 08:08 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I will take all of these and the bell housing. Please pm me and I will give you my adress so we can get a final price with shipping. Thanks.
Old Apr 19, 2010 | 04:10 PM
SCCAjunkie's Avatar
Car: 84 Z28
Unfortunately, you were too late for the hydraulics.
Clutch m/c and slave SOLD, package price reduced to reflect that.
Old Apr 19, 2010 | 07:22 PM
1985 camaro 350's Avatar
Car: 1985 camaro
Engine: 360
is the bellhousing for a v8? if so i will buy it
Old Apr 19, 2010 | 08:10 PM
SCCAjunkie's Avatar
Car: 84 Z28
Yes it is, as far as I know. I never knew there was a difference...
Old Apr 19, 2010 | 08:30 PM
Car: 1985 camaro
Engine: 360
i didnt know there was a difference either until today. could u check to make sure its a v8 bellhousing and give me a price shipped to 73501 if it is?
Old Apr 19, 2010 | 08:42 PM
SCCAjunkie's Avatar
Car: 84 Z28
How would I know the difference? What can I look for?
Old Apr 21, 2010 | 12:37 PM
8airoc's Avatar
you still have the slp runners?? how much to 79912
Old Apr 22, 2010 | 09:28 PM
SCCAjunkie's Avatar
Car: 84 Z28
PM sent.
Old May 30, 2010 | 03:16 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
do you still have the runners? are they earlier or later tpi setup?
Old May 30, 2010 | 08:28 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
intrested in the y pipe, whats the collector sizes?
Old May 30, 2010 | 08:58 AM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
If 1985 camaro 350 doesn't take the Bellhousing, I will. Just be sure it bolted to the V8 please and it is for hydraulic clutch slave. Should be. Shipping quote to 46077.
Also, when u find pedals and top plate let me know how much. Again, just PM or E-Mail me. Thanks again
Old May 30, 2010 | 12:11 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Interested in the fuel rails. Please send pics to t.stang@live.ca
Are the injector holes clean and not marked up? Because I know guys like to shove flat heads in them to pry the injectors out.
So please send me detailed pics of the injectors openings.
And is there anything else wrong with them?
Old Jun 9, 2010 | 03:22 PM
Ryanb56's Avatar
I am interested in the shifter, bellhousing, and clutch fork if you can give me a shipping quote to 83843. Also pics of these items to braunryan@hotmail.com would be great if you can. Thanks.
Old Jun 13, 2010 | 03:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm interested in the stock throttle body if it is for an 1989 to 1992 car.
Old Jun 14, 2010 | 11:04 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Do you still have the stock memcal? (chip)?
Old Jun 17, 2010 | 02:08 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Anyone hear anything from this guy lately or know how to get ahold of him?
I tried a PM and the email address listed on his profile, both 3-5 days ago and nothing(???)
Anyone else get any response after showing interest in an item(s)?
Old Jun 17, 2010 | 07:23 PM
86transam.man's Avatar
Car: 1986 Firebird Project
Engine: 3.1L
Transmission: t5
I sent pm also but only a day ago and have heard nothing. I am interested in the hurst shifter.
Old Jun 21, 2010 | 11:09 AM
87SSTPI's Avatar
Well, too bad I guess
Old Jan 28, 2011 | 10:14 PM
ajfincannon's Avatar
Car: 1991 z28
Engine: 5.7
Transmission: 5 speed swap
is the bell housing for v8 if so send me piv message and i will more than liky get it
Old Jan 29, 2011 | 04:01 AM
87SSTPI's Avatar
ajfincannon, This is one of those "drive-by" for sale postings. You know, they are here one second and then they never post again after people show interest in their parts. I wouldn't waste your time, but good luck.
Old Feb 8, 2011 | 05:57 AM
dsudzina's Avatar
Hi,
Do yo still have the clutch fork rubber boot and the bellhousing inspection cover? I have a 1983 daytona with a 305, and need these 2 parts. Thanks, Dave
Old Feb 8, 2011 | 06:23 PM
nealey82's Avatar
Car: 92 25th anniv. camaro
Engine: ls-6 V8
Transmission: t-56 6 speed
Axle/Gears: 3:73
u still have the t-5 bell housing?if so how much shipped to 28376. was it a 305 or 350?
Old Mar 20, 2011 | 08:00 PM
SCCAjunkie's Avatar
Car: 84 Z28
87SSTPI- I didn't get the message, and obviously haven't been on here in a while. I wouldn't call someone with 48 posts in a variety of forums a "driveby". Your inquiries were 2 months after the original post...
That said, I'll have to look what I have left of the trans. stuff. The ported TPI setup is gone. I still have the following items---
Y-pipe
Stock TPI pieces
LS1 injectors
Wheels
Park light housings
I'm in a deal-making mood.
If interested, email me at-- mattgreen((at))msquaredracing((dot))com
Old Mar 22, 2011 | 10:11 AM
Formula383's Avatar
Car: 88 Firebird Formula
Looking for the SLP Y Pipe. Sent pm
Old Mar 22, 2011 | 10:53 AM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
do u still have the hurst shifter and the lower shift boot?...
Old Mar 22, 2011 | 07:21 PM
SCCAjunkie's Avatar
Car: 84 Z28
Reply sent on Y-pipe.
I'm still not sure on the trans parts. They are at my shop, and I am not there this week.
Old Mar 27, 2011 | 09:05 PM
SCCAjunkie's Avatar
Car: 84 Z28
Y-pipe is sold, paid, and delivered.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
