[FL] PARTING 84 Z28 H.0 CAR 5 SPEED 373 DISC PICS
Suspended
Car: 91rs camaro conv
Engine: 305 tbi
Transmission: 700r4 w/shift kit
PARTING 84 Z28 H.0 CAR 305 H.0 MOTOR 5 SPEED TRANS FACTORY 373 POSI
DISC REAR CAR IS A ODD COLOR IT WAS PAINTED A BUNCH OF DIFFERENT COLORS THAT WERE COOL BACK IN THE 80'S ON DISCO VANS
BUT THE MOTOR TRANS AND REAR ARE GOOD INTERIOR IS TAN NO DASH PAD OR HEADLINER
LARGE STUFF NEEDS TO BE PICKED UP IN TAMPA FL
YES I KNOW IT HAS A 91 NOSE ON IT
REAR IS SOLD
TRANS AND SHIFTER SOLD
BUT THE MOTOR TRANS AND REAR ARE GOOD INTERIOR IS TAN NO DASH PAD OR HEADLINER LARGE STUFF NEEDS TO BE PICKED UP IN TAMPA FL
REAR IS SOLD
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: PARTING 84 Z28 H.0 CAR 5 SPEED 373 DISC PICS
i need 2 pieces off the rear end....passenger side e-brake cable mounting bracket & screw and the spring that pushes the lever to release position...i'm desperate!!!!!
Suspended
Engine: 305 tbi
SORRY MAN REAR IS GETTING SOLD AS A WHOL
Want a title? Post!
Car: 91 Camaro RS
Axle/Gears: 3:73 posi
what is the condition of the drivers side door and fender?
Suspended
Engine: 305 tbi
SORRY REAR WAS SOLD LOCAL YESTERDAY
TRANS AND SHIFTER SOLD TOO
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
How much for the hydraulic clutch assembly? From the pedal to the slave cylinder?
Suspended
Engine: 305 tbi
U WANT THE LINE WITH THE LITTLE PLASTIC CUP ON IT RIGHT RUNS DOWN TO THE TRANS??
Yes the entire thing. Disconnected from the clutch pedal and and the slave from the transmission. The reservoir and the bracket would be nice also.
How do I send the money to you? I also would like the part that attaches the rod to the pedal.
Suspended
Engine: 305 tbi
75 SHIPPED FOR THE AIR CLEANER (NO TUBES)
HARNESS WAS CUT SORRY
Car: 1983 Z-28
Engine: 5.7 L
how much for the cover of the thermostat with fan thermostat and the other parts it has connected?...
Want a title? Post!
Car: 84 Z28
Engine: L69 5.0 HO
Transmission: 5 speed
WHere was the wiring harness cut? By the fire wall? I really could use the connectors if they are still intact. My wires were chewed through by rats so I have ost of the harness minus a few of the end conectors. I could peice one together if you have any of it left.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
