[IL] LB9 305 engine, heads
Old May 20, 2010 | 01:38 PM
IrocZ'85's Avatar
Car: '85 IrocZ
This 305 is out of my '85 IrocZ and the odometer shows 125,000miles, but I'm not entirely sure about this motor in particular. This is NOT the STOCK '85 engine, as it has a roller cam and they didn't exist in '85. The casting number on the back of the block is #14093627-5.0L-SG1. This motor is listed to be produced between 1988-94. The previous owner must have swapped this motor in. Ran very strong except that it burned oil, so would probably need a rebuild. It would be great for a little project though. I removed the cylinder heads to sell them separately.
~~SOLD!~~Engine: Ca sting #14093627. Consists of entire bottom end, pistons, rods, crank, cam, lifters, etc... Does not have cylinder heads. Flexplate included, I tried to remove the flexplate but there was a fussy bolt. Here are some pictures:
http://i26.photobucket.com/albums/c1...s/DSC_0341.jpg
http://i26.photobucket.com/albums/c1...s/DSC_0168.jpg
http://i26.photobucket.com/albums/c1...s/DSC_0167.jpg
Heads: Cylinder heads from the same 305 LB9. Casting number #14101081. These are the factory 58cc port heads, might work great for high compression on a 350 build. Comes with stock valves, rockers, and springs. They are kinda dirty but with a little cleanup should run well.
Here are pics:
http://i26.photobucket.com/albums/c1...s/DSC_0171.jpg
http://i26.photobucket.com/albums/c1...s/DSC_0170.jpg
I was thinking $50 for the engine, and around $90 for the heads. Prices aren't final, make me an offer! If you want more pics, let me know! Also, you would have to come and pick up these parts. Thanks!
Old May 21, 2010 | 02:38 PM
IrocZ'85's Avatar
Car: '85 IrocZ
Re: LB9 305 engine, heads
bump!
Old May 27, 2010 | 06:13 PM
IrocZ'85's Avatar
Car: '85 IrocZ
Bump! Engine sold, i still have the heads!
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
