[PA] TPI set up / Motorvation reprogrammed ECU (much lower prices)
Old May 31, 2010 | 09:08 PM
dpmalibu's Avatar
I have a TPI manifold w/ Accel 24 lb injectors, BBK 58 mm Throttle body,Intake runners are polished. Also have the HEI distributor and Mass air flow sensor that was in the same motor. All aftermarket parts have 1500 miles on it. This set up came out of a 1986 Z/28. Asking $400 B/O (now missing fuel pressure regulator).
Also have a Motorvation reprogrammed ECU came from same motor the cam that was used in this set up was Crower #00231 Forced induction cam $150 B/O
i will have pics tomorrow.
Located in Hatboro,Pa
Old Jun 5, 2010 | 09:37 AM
dpmalibu's Avatar
Re: [PA] TPI set up / Motorvation reprogrammed ECU
prices for parts separated:
Upper/lower TPI manifold w/ runners bare w/o adj. fuel pressure regulator , injectors or throttle body $125
BBK 58MM Throttle body $175
BBK adjustable fuel pressure regulator $40
Accel 24lb injectors $150
All parts have 1500 miles on them.
Old Jun 10, 2010 | 06:31 PM
dpmalibu's Avatar
Make me an offer.
Old Jun 12, 2010 | 10:07 PM
dpmalibu's Avatar
Re: [PA] TPI set up / Motorvation reprogrammed ECU (much lower prices)
lower prices.
Old Jan 24, 2011 | 03:45 PM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
hi, do you still have the MAF sensor?
Old Jan 25, 2011 | 03:14 PM
dpmalibu's Avatar
sorry its long gone.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
