[IL] 3.45 Aluminum caliper,posi, 9 bolt from 89 formy/trade for 3.42 or + 4th gen rear.
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
100% complete with good pads/rotors...its still in the car.
no noises, posi works great.
this is the big rotor/aluminum caliper version with 3.45 ratio factory.
Im wanting to trade this for a 3.42 ratio or higher numerically rearend from a 4th gen{going to 4th gen rims, want to avoid spacers}
3.42/3.73/4.10 are ok, please nothing over 4.10 though.
rearend you have must be complete,and in the same shape as mine!
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 3.45 Aluminum caliper,posi, 9 bolt from 89 formy/trade for 3.42 or + 4th gen rear
Should we guess the price? Location?
On Probation
not putting a price, because its not for sale, only trade for 4th gen rear!
location clearly states illinois...but zip is 60417 for those interested.
since some whiner will nag about a price, i want 9600 bucks cash, or trade for 4th gen rear like mentioned above
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
I have a 4th gen rear that has 2.73 gears. We robbed the disk brakes off it for another project. If your interested Ill let it go cheap as I have no use for it.
On Probation
thank you, but i will pass,i really do not want to deal with a rebuild and gear swap.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
