[NH] 350 engine, bored .040 over, edelbrock intake, misc stuff
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This came in a car I bought. The previous owner had it built up.
It's a 2 bolt main 350, 2pc rear main seal, NON roller. He had it bored .040 over. I can't tell if the pistons are forged or not. Lets say no. It's a block, crank, rods, and pistons assembled as such. He had some 882 heads on it, and the edelbrock cam/intake/carb package and it ran pretty good. The valve covers leaked bad so it's pretty dirty, but the bearings and cylinders look like it's got less than 5k on it.
I threw the cam, timing chain out.
So for the block, crank, rods, and pistons as assembled I'd like around $350.
I'd throw the heads in as I have no use for them.
I also have an edelbrock performer intake EDL-2101 (not rpm).
It has a little block off plate too, which I'm thinking is egr ? I dunno. $75
I also have a speedo sleeve for a TH400. 1362076 for 36-39 tooth driven gears. $20
-- Joe
-- Joe
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 350 engine, bored .040 over, edelbrock intake, misc stuff
Roller block? Oil pump? Pics?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
theshackle
Sep 17, 2020 08:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
