730 ecm with AUJP prom and standalone harness
Old Jun 17, 2010 | 09:27 PM
jonarotz's Avatar
Car: 91 Z28
I have a 730 ECM, AUJP memcal/prom and a stand alone harness that I might be willing to let go. I have been into the aftermarket DFI stuff now and really don't have a need for this stuff anymore so I am just trying to figure out if there is still a market for this stuff and how much it is worth.
Old Jun 23, 2010 | 07:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: 730 ecm with AUJP prom and standalone harness
How complete is the harness and what are you looking to get for it
Old Jun 23, 2010 | 09:01 PM
jonarotz's Avatar
Car: 91 Z28
It will run an engine. It has the injectors, ECT, IAT, O2, map, knock...etc. I think the only thing it will need is the fan and fuel pump relay. It is set up to be stand alone, so no VATS or speedo buffer or anything.
Old Jun 24, 2010 | 12:31 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I may be intrested in just the stand alone harness, got pics???
Old Jun 27, 2010 | 06:49 PM
jonarotz's Avatar
Car: 91 Z28
PROM is sold.
I will try to get pics of the harness tomorrow.
Old Jun 27, 2010 | 06:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally Posted by jonarotz
PROM is sold.
Thanks, would like to find the short cut or easy way to put the 2.8 MPFI in my Bird into my S15 that had a carbed 2.8 and still keep the computer in the Bird to run some functions / I don't wanna havfta pull all that wiring out.
Old Jun 28, 2010 | 06:12 PM
jonarotz's Avatar
Car: 91 Z28
Here is the engine side of the harness. It has hookups for battery, ECT, IAT, TPS, IAC, MAP, leads for fan and fuel pump relays, distributor, knock, O2, engine grounds, and injectors.
Attached Thumbnails 730 ecm with AUJP prom and standalone harness-engine-end.jpg
Old Jun 28, 2010 | 06:18 PM
jonarotz's Avatar
Car: 91 Z28
Here is the ECM side. It has the 3 ECM connectors, ALDL plug, VSS, flying leads for ALDL ground, 12v keyed, SES/check engine light, PRNDL....mmmm I think thats it.
Attached Thumbnails 730 ecm with AUJP prom and standalone harness-ecm-side.jpg
Old Jun 28, 2010 | 06:25 PM
Mr. Notorious's Avatar
so that's for the speed density style injection?
Old Jun 28, 2010 | 06:28 PM
jonarotz's Avatar
Car: 91 Z28
Yes, speed density.
Old Jun 28, 2010 | 06:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good Lord could you make those images any bigger
They keep crapy out, I get about 1in loaded n the connection to the forum dies.
Old Jun 28, 2010 | 08:56 PM
jonarotz's Avatar
Car: 91 Z28
Try these....
Attached Thumbnails 730 ecm with AUJP prom and standalone harness-ecm-side_2.jpg   730 ecm with AUJP prom and standalone harness-engine-end_2.jpg
Old Dec 9, 2010 | 04:50 PM
jonarotz's Avatar
Car: 91 Z28
Bump for the harness
Old Jan 29, 2011 | 09:39 PM
69cutlass's Avatar
Pm'd you
F.I. 57 Belair
Aug 23, 2021 01:09 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Billy Decker
Sep 4, 2015 03:46 PM
