[WA] Getting out of third gens
Old Jun 28, 2010 | 03:38 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Selling everything third gen related (except my T56) Getting into A bodies.
ENGINE PARTS: Sealed power 2 relief flat tops (std bore, use for less than 5k), Speedway 4340 H beam rods, Ramjet setup, Fidanza aluminum LT1flywheel and Ram HD LT1 clutch (less than 10k on flywheel and clutch).
92 Formula rolling chassis with new tires, BW 9 bolt (3.70 gears, rebuilt posi), LS1 front brakes, SLP 1 3/4" shorties w/ Y pipe and full exhaust, frame ties, complete serpentine setup with smog delete, AC (worked when I last drove it) and power steering pump. Aluminum driveshaft. Factory TPI harness is modified for the sensors on an LS1 throttle body.
$1800, come and get all of it.
Old Jun 28, 2010 | 11:53 PM
RussellTibbits's Avatar
Re: Getting out of third gens
How many miles on the heads?
Old Jun 29, 2010 | 12:33 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Would you be willing to separate and ship the Ramjet?
Jon
Old Jun 29, 2010 | 04:10 PM
Car: 1991 Camaro RS
Russell, less than 5k on the heads (and the bottom end, in case anyone else was wondering) Never floated the valves, never any contact with pistons. Pics can be had if you want. (easier to email them to you, don't have to ruin the quality to post)
Jonathan, I may cosider shipping the ramjet... I didn't buy the kit, I got a bare manifold and pieced the rest together. Never got a set of proper fuel lines on it. What all are you wanting, a complete swap or just some pieces to help get you there?
Old Jun 30, 2010 | 07:21 AM
Car: '83 Berlinetta
Engine: 383 CI
I'm running a carb at the moment so I'd eventually need everything.
Jon
Old Jul 4, 2010 | 11:40 AM
Car: 1991 Camaro RS
I really would like to leave the harness and ecm in the car. The manifold, throttle body, throttle cable bracket, fuel rails and injectors would be the portion I would sell...
Old Sep 27, 2010 | 04:21 PM
Car: 1991 Camaro RS
Clearing the dust off this old thread. Updated, sold the heads and the block/valvetrain stuff. Willing to trade for stuff that helps me get my 67 Skylark together.
Old Sep 30, 2010 | 12:26 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Got any pics of the Fidanza aluminum LT1flywheel as id be interested in it. Also how much milage is on it???
Old Sep 30, 2010 | 04:12 PM
Car: 1991 Camaro RS
Can't find the camera at the moment, I'll work on finding it and getting some pics. I've put about 10,000 miles on it, mostly hiway and back roads. Only 5 passes at the dragstrip. 1 pc seal, ext. balance.
Old Oct 3, 2010 | 11:33 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Pmed you the other day, how much for the smog delete pulley shipped to 65020?
Old Oct 4, 2010 | 12:31 AM
Car: 1991 Camaro RS
Pic of flywheel for 6SIX6.
92z28camarokid, I'd take $55 shipped for the smog delete.
Old Oct 4, 2010 | 01:08 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
PM sent
Old Oct 4, 2010 | 08:58 AM
6SIX6's Avatar
Car: 89 IROC
What where you looking to get for the flywheel??
Old Oct 4, 2010 | 09:20 AM
Axle/Gears: stock
PM sent
Old Oct 8, 2010 | 04:44 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
how much for the alluminum drive shaft and ill it fit my third gen its an 86 with a th700r-4
Old Oct 8, 2010 | 04:54 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Do you have the mounting bracket for the cruise control for a 90 Trans Am? I also need the 5 conductor water proof plug (both halves) for a IROC with dual fans.
Thanks Andy
Old Oct 8, 2010 | 10:03 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
do you have any pic's of the frame ties...who's are they, how much to 49037 michigan.
thanks
Old Oct 8, 2010 | 11:06 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Uncle Skeletor,
I've got a brand new pair of rear lowering springs for you're '67. I bought them for my 66 but they won't work. They are Classic Suspension units for a 2" drop. Want them? What do you have to trade?
Old Oct 9, 2010 | 08:47 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
the flywheel was for a 2pc or 1pc rear main seal setup?
Old Oct 13, 2010 | 04:26 PM
Car: 1991 Camaro RS
black-bandit - $75+ship on driveshaft, new slip yoke 10k ago, new u-joints 20k ago.
ringo234 - my car came from the factory without cruise control, it was a stripper model (nothing but performance options and AC). Really don't want to hack up the wiring harness, I want the car to run again someday.
gscz28 - frame ties are welded to the car, haven't really considered cutting them off, more of a feature for whomever buys the car.
wesilva - if it were a set with all 4 springs, I'd be a bit more interested.
ownor - 1 pc seal
Old Oct 16, 2010 | 04:09 AM
DiabloWS6's Avatar
is it an aftermarket driveshaft or replacement 1LE
Old Oct 18, 2010 | 12:18 AM
Car: 1991 Camaro RS
Factory driveshaft from a '90 trans am I had a few years back. It wasn't a 1LE, but it is aluminum.
Old Oct 19, 2010 | 06:20 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Are you parting the formula? I am interested in the LS1 front brakes and the fog lights. PM me if you're interested.
Old Oct 20, 2010 | 04:35 PM
Car: 1991 Camaro RS
Not trying to part the car necisarrily. It's too good to part out. I'd love to sell it as a roller, but there's too many good parts to let it go dirt cheap. I'm only selling major things that are easily replaced with run-of-the-mill stock parts.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
