[Sold] Vortec TPI Intake Base, heavily ported
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I have for sale a OEM 1985 TPI intake base modified to fit the Vortec cylinder head bolt pattern and is heavily ported.
There is nothing wrong with this intake. Material has been added to the flanges to so they can be drilled and fit to the Vortec bolt pattern. The modifications were not done by me. I bought this intake base for the plenum and runners that were attached to it. I am not running vortec heads so I have no use for it.
This is also heavily ported. The runner ports are around the same size as the TPiS Big Mouth intake base, they've been enlarged to about 1.6 inch and are ported all the way through the runner to the cylinder head ports. The cylinder head ports are about 1.32" x 2.27".
When I bought this it was painted. I stripped the paint and have cleaned it up. It has not been bead blasted yet It will need repainted if you want it to look good. I will sell it as is or for an extra charge I can bead blast and paint it for you.
Ask for pictures. I'll try and get some up but this thread is being fussy with me when I've tried to get the pictures loaded. Hopefully I can get them up soon.
As is - $60 plus shipping
Bead Blasted and Painted - $80 plus shipping (you specify color)
(this base came off of a 406 small block making around 500rwhp)
Re: Vortec TPI Intake Base, heavily ported
bump...
A few pictures...
OEM casting number....
bump....
Intake is SOLD
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
