[TX] FS: stock spindles from '90 formula modified for flynbye C5 brake kit
Old Aug 5, 2010 | 12:46 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
$50 plus the ride.
Dust cover bolts are drilled and tapped for 7/16" fine thread bolt. Drill and tap operations done on a vertical mill for perfect alignment. Old caliper mounts cut off to clearance for new C5 caliper.
I'm sure other calipers (C4, LS1 etc) will work as well, but check before you buy.
Old Aug 6, 2010 | 10:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: FS: stock spindles from '90 formula modified for flynbye C5 brake kit
is this just for the spindles, or hubs too? thanks!
Old Aug 7, 2010 | 07:25 AM
Andrew91GT's Avatar
Car: 1990 formula
Only spindles. I had to reuse the hubs for my racecraft spindles.
Old Aug 25, 2010 | 09:07 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
PM sent
Old Sep 7, 2010 | 04:47 PM
pondriver's Avatar
Engine: 350 HSR
PM sent
Ed1LE
Sep 30, 2018 09:14 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
rb85TA
26
Sep 14, 2015 10:29 PM
