Lunati Cam Bracket Master II
Car: 84 Trans Am
New never installed Lunati Cam. It is the Bracker Master II $75
Below are the specs from summits site
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,000-6,000
Intake Duration at 050 inch Lift 230
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 230 int./230 exh.
Advertised Intake Duration 292
Advertised Exhaust Duration 292
Advertised Duration 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.480 in.
Valve Lift with Factory Rocker Arm Ratio 0.480 int./0.480 exh.
Lobe Separation (degrees) 109
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Nov 11, 2015 10:46 PM
