[OK] lt1 intake and fuel rail
Old Sep 25, 2010 | 12:43 AM
MPIpowered4x4's Avatar
For sale: lt1 intake manifold and fuel rail.
This is the perfect intake for the Lt1 intake swap, its cheap and comes with the correct fuel rail to clear the distributer.
$50 shipped.
Old Sep 25, 2010 | 02:17 AM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
Re: lt1 intake and fuel rail
how much would shiping be to V0N 2P0
Old Sep 25, 2010 | 03:17 AM
$85 total to your door.
Old Sep 25, 2010 | 10:42 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
If he doesn't take it I will give you $50 for it.
Old Oct 1, 2010 | 03:23 AM
ttt
Old Oct 2, 2010 | 10:45 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Would this work with Vortech heads?
Jon
Old Oct 2, 2010 | 11:50 PM
No, I don't think so, even with the modifications you have to do to make it fit old style chevy heads, cant be done with this, i dont think the ports will line up
Old Oct 3, 2010 | 01:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by MPIpowered4x4
even with the modifications you have to do .... cant be done with this, i dont think the ports will line up
No ?
https://www.thirdgen.org/forums/alte...-swappers.html
https://www.thirdgen.org/forums/alte...onversion.html
Old Oct 3, 2010 | 01:33 AM
The l98 heads are not vortec heads, I only browsed through some of it, but I have yet to find one person modify an LT1 intake to work with vortec heads.
You could weld up some bungs for the vortec bolts to go through, anything is possible
Old Oct 3, 2010 | 11:00 PM
Car: '83 Berlinetta
Engine: 383 CI
Mine is a Gen 2 block with aluminum Vortec heads (the GMPP "Fast Burn" ones) so the bolts should line up without modification. My question had really been about the ports.
Jon
Old Oct 4, 2010 | 08:22 AM
Jon
I don't know, that is something you might want to research. it is cheap enough, its worth a try.
You might can gasket match it and they might line up.
Old Oct 4, 2010 | 08:44 PM
Car: '83 Berlinetta
Engine: 383 CI
Thanks. I'll look into it.
J
midge54
Dec 27, 2019 04:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
