305 TPI & T5 w/headers & pulleys CHEAP!
Old Sep 28, 2010 | 01:05 PM
dan_needs_a_ws6's Avatar
Car: '91 Firebird
Engine: 305 TBI
Transmission: 4 Speed Auto
Axle/Gears: Stock 2.73's with drums
Hello everyone, I'm selling a model year 1986 305 TPI and BW T5-from coolant hoses to torque arm mount. I pulled it from an '86 Trans Am I bought back in May. It ran on 7 cylinders at first, I then cleaned up the cap and whatnot, threw new plugs in it. Fired the engine one last time in July-ran much better until the fuel pump died. So after that I decided it was time for an LS swap so I pulled the 305 and tranny together in an effort to sell.
Engine comes with upper and lower hoses, March underdrive pulleys (crank, water pump, alt), a/c delete pulley, power steering pump, intake tube with MAF sensor, complete Tuned Port assembly, distributor, Hedman long tube headers, slave and master cylinder, bellhousing, clutch is shot-will need a clutch, transmission, all mounts, shifter, starter, oil/filter, and harness and PCM are optional at no additional cost.
The harness I am in the process of trimming for power wires to splice into LS harness. Harness will come with fuel pump and MAF relay-no cooling fan relays-and be ready to splice into your vehicle harness.
I'm located in upstate NY and am selling this for pick up only-NO SHIPPING. Asking price for everything listed is $800. I'm posting this with no pics so if you want some, I'll have to email them. Thanks for looking.
Old Oct 1, 2010 | 05:09 PM
1RedCamaro's Avatar
Re: 305 TPI & T5 w/headers & pulleys CHEAP!
let me know if you want to sell just the tpi setup
Old Oct 2, 2010 | 03:36 PM
1meanbird's Avatar
Want a title? Post!
Car: 87 formula
Engine: 355 c.i
Axle/Gears: strange posi 3.42
let me know if you will sell the pulleys seperate, shipped.
Old Oct 11, 2010 | 02:47 PM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
yeah, I'm interested in the headers shipped as well... 27360
Old Nov 15, 2010 | 12:12 AM
Whiteaw57's Avatar
Car: 1990 Camaro RS (Racecar)/1991 Z28
Engine: 355 Race Engine/Stock TPI 350
Transmission: Borg Warner T5/Borg Warner T5
Axle/Gears: 4.10/2.73
interested in headers to 28144
Old Nov 15, 2010 | 11:25 AM
87ttopta's Avatar
Want a title? Post!
you still need a tpi setup
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
slowsi
Oct 18, 2015 08:49 PM
Damon
Sep 26, 2015 04:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
