L-98 Rotating Assy
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
L-98 Rotating Assy
L-98 One Piece RMS - Rods/Pistons/Rings/Bearings/Timing Chain Set
Selling the eng parts I purchased to rebuild a 1988 L-98 since I ended up scrapping that project. If you're into rebuilding engines or getting ready to rebuild yours soon, here's an opportunity to save some money. All parts are new in box/original packaging with the exception of #1. #1 - I was told has 5,000 miles on it and it looks new, bought here from a member.
1. Cloyes True Roller Timing Chain - CLO-9-3157 (used) sold new for $97.39, has <5,000 miles. Bought used for $35.00.
2. Eagle SIR I-Beam Connecting Rods - ESP-SIR5700BPLW - 565 Grams, new in box... $235.95
3. Sealed Power Pistons - H-345NP (+.030) - Flat top, 4-valve relief, press fit pin, set of 8, new in box... $96.00
4. Clevite-77, Main Bearing Set, MS-909P Standard size - New in Box... $25.95
5. Clevite-77, Rod Bearing Set, CB-663P Standard size - New in Box... $22.00
6. Sealed Power Rings - E-251K - New in Box... $35.99
I spent over $450.00 on everything, package deal for $250.00 plus shipping.
Magman
Magman
