[CA] Parting Out: 10 bolt Posi Rear axle & parts 88-2002 3rd & 4th Gen F Body
Old Oct 15, 2010 | 04:59 PM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
From a 2000 Camaro SS: I bought it for the 3.42 gears and diff. I already sold the brakes, I want the rest gone, Someone must need some of this stuff. Don't be afraid to make me offers. Note that this is 28 spline stuff.
2.73 Auburn series 2 posi stuff from my 94, details posted lower in this thread $100 OBO (Plus shipping if not local pick up) **SOLD**
Housing w/ L&R Bearing Caps, Diff cover, less Gears, Carrier, brakes, and Sway bar. - $20
L&R 28 spline, 5-lug Axles with Traction Control/ABS Reluctor rings (for 4 channel), and C-clips. - $50 **SOLD**
L&R Traction Control/ABS Speed sensors - $20 for the pair **SOLD**
Old Oct 16, 2010 | 04:46 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Re: Parting Out: 10 bolt Rear axle housing & parts 3rd & 4th Gen F Body
Whole housing for 50 bucks?
Old Oct 16, 2010 | 06:03 PM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
And your willing to pay for and arrange the truck freight pickup from Nor Cal to WI????
Old Oct 16, 2010 | 06:43 PM
Engine: 357
Lol i wasn't going to say that but its a good deal!, i would if you were closer. Maybe roadtrip the 305 lolol.
Old Oct 16, 2010 | 07:12 PM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
No worries, I got a chuckle from your interest. I think on the housing it will need to someone within driving distance, which, is subjective ....
Old Oct 16, 2010 | 10:37 PM
Engine: 357
Id be on it in a heartbeat if it was closer, but good luck with your sale!
Old Oct 18, 2010 | 07:08 PM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
Thanks, eventually someone local enough will want some of this.
Old Oct 18, 2010 | 07:15 PM
Vinitine's Avatar
Car: "86 Camaro
Engine: 2.8L V6
Transmission: A4
Sorry for the rookie question but will that bolt right to my 86? and is it better than my stock rear as far as gears and what not?
Old Oct 18, 2010 | 07:32 PM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
No problem.
Will that bolt right to my 86?
Yes, it will bolt right up
Is it better than my stock rear as far as gears and what not?
That depends on what your really asking: It does not have gears, IE, no ring, pinion, or carrier.
If your asking if it's better because you thought it included gears, no, it's not, your stock one probably has gears and works.
I am not sure if the 2.8 v6 and V8 86's have a different rear axle, I suspect they are both exactly the same 10 bolt housings, just with different gears and carriers. So, really, it's the same housing you already have.
You would need to look at your RPO codes to see what Axle assembly your car has. Someone more familiar with that year can answer better than I can.
This is a great deal for someone who wants just a housing, and/or axles, and/or some sensors.
I will have my 94's original 2.73's and the Auburn Posi available after tomorrow, if you want to get the parts to swap the internals in your housing.
Old Oct 20, 2010 | 10:04 AM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
I swapped out my 2.73 Auburn series 2 posi stuff yesterday for the 3.42 Zexal/Torsen from the housing posted in this thread, so it's available now. I'll get some pics up later today. Works great, launches well.
It consists of the Auburn posi with the ring gear, and ABS Reluctor tone ring, and the pinion.
Richmond makes gears for the series 2 carrier as low as 4.56. (I'm sure there are other brands as well)
Old Oct 24, 2010 | 09:36 AM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
Re: Parting Out: 10 bolt Posi Rear axle & parts 88-2002 3rd & 4th Gen F Body
btt, still have this stuff for sale. don't be afraid to make offers
Old Mar 3, 2011 | 11:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
would u part that 2.73 posi ring & pinion? I see no problem dropping that into a 3rdgen housing right?
Old Mar 4, 2011 | 12:49 AM
uNkleStv's Avatar
Car: 94 Z28
Engine: 5.7 LT1
I sold it already. All I have left is the housing for $20. It would be a great source for brackets and tubes for a 12 bolt swap or 8.8 hybrid
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
