[Sold] FS Very built 700r4, stall, b&m cooler, ratchet shifter and more....
Old 10-21-2010, 10:05 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Doing a t56 swap into the trans am this stuff is all only 1k miles since built,
700r4 trans built for my hp level by Jim at Nowthen transmission best of everything including hydraulic lock up control (no wires needed)
Finned polished aluminum deep pan (filled with amsoil since new) (if pulled complete will leave all in)
Rev Max 3k rpm stall converter flashes closer to 3300 with my engine
TCI sfi flex plate, ARP bolts for the flex and TC
fully adjustable "screw" style tv cable, Holley geometry correction adapter, and holley TV cable mount, locking dipstick tube.
powder coated cross member
trans and converter both have warranty, trans till September of next yr, converter till august
includes my B&M stacked cooler with 8" spal e-fan aeroquip lines and fittings as well.
Lastly price includes my B&M ratchet shifter, console plate etc... and 2 t handles, one polished one black/red powder coat
also the inspection cover is pc'd silver
trans was stripped and painted a high gloss catalyzed epoxy paint prior to build looks very nice
I have well over 3k into this set up will not separate unless buyers are lined up for everything
I can give ride to show it functions 100%
Or I plan to pull it this weekend for quick sale.
1200 obo cash talks!
pics available upon request, however it is installed and pics might not show well
s/h will be at your expense crateing charge may apply
jwdomino is offline
Old 10-21-2010, 10:23 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: FS Very built 700r4, stall, b&m cooler, ratchet shifter and more....
You know... I really wish you'de posted this thread a WHOLE lot sooner. I just spent that much on my trans and torque converter and it's nowhere near that built And it's a TH350... Bah.
Good luck with the sale. Sounds more than fair considering what it costs to build these correctly.
DeltaElite121 is offline
Old 10-21-2010, 10:25 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
thanks for the bump!
jwdomino is offline
Old 10-22-2010, 03:44 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
IF...you were to seperate.
How much for the cooler,lines,fittings and shipping to 67147 KS
Slush92RS is offline
Old 10-23-2010, 07:02 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
If seperating, how much for the shifter?
19 z28 92 is offline
Old 12-02-2010, 03:59 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
sorry guys this sold a few days after I posted it, forgot to update
jwdomino is offline
Hotrodboba400
12-10-2019 07:07 PM
apie2546
09-05-2015 07:40 PM
rjcme
09-05-2015 01:23 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: [Sold] FS Very built 700r4, stall, b&m cooler, ratchet shifter and more....
