[MI] 396 SBC Engine For Sale, Parts List.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Feeler!! Just Ask
396 SBC Engine For Sale, All top quality parts. Costs about $8000 to replicate. Roughly $3000 in the bottom end and $5000 in the top end, $1000 in portwork alone. It was built for True Street racing with a LOT of nitrous in mind. Bottom end has a few thousand miles on it and the refreshed top end has 2 summers of driving on it. Idles nice, shifts at 7500. It ran 9.85 @ 140 with less cam, no portwork, and a 200 shot. My goal here was 8.90's with these parts and a 300 shot. @ 3400lbs. Time to get out of it.. Engine should make 625-650hp roughly with the small carb and headers. Before portwork and with a smaller cam it ran 11.0's at 127+. 9.80's with a 200 shot.
$3500 Complete Engine
$1200 Bottom End
$2300 Top End
Bottom End:
1973 4 Bolt block
ARP Main Studs
Hardblock filled to the freeze plugs
Stroker clearanced
Eagle 4340 3.875" Crank
Eagle H-beam Rods 6.00"
Diamond Pistons 4.030" -4cc reliefs
11.5:1 Compression, Total Seal AP Gapped rings .028"
Melling HV Pump
Canton Oil Pan, 82-92 F-Body road race model
Top end:
Pro Systems 780 Holley Carb
K&N 3" Extreme Airflow Filter/Lid
ARP head Studs
Edelbrock Super Victor Intake Port matched
Dart Pro 1 230cc heads 64cc, Angle plug
-- Ported by Lloyd Elliot, Milled .010"
Bullet Cam's Solid Roller 259/263 @ .050" .688", 112 LSA Small base circle
Bullet VS3100 Springs
Comp Cam Solid Roller Lifters
Comp Cam Pro Magnum roller rocker arms 1.6
Billet roller timing set
Trend .080" Pushrods 8.200"
$1200 Bottom End
$2300 Top End
Bottom End:
1973 4 Bolt block
ARP Main Studs
Stroker clearanced
Melling HV Pump
Top end:
ARP head Studs
Re: 396 SBC Engine For Sale, Parts List.
Feeler!! Just Ask
$1200 Bottom End
$2300 Top End
Bottom End:
1973 4 Bolt block
ARP Main Studs
Stroker clearanced
Melling HV Pump
Top end:
ARP head Studs
$1200 Bottom End
$2300 Top End
Bottom End:
1973 4 Bolt block
ARP Main Studs
Stroker clearanced
Melling HV Pump
Top end:
ARP head Studs
Transmission: 4L65E
This is a standard 350 4 bolt block that now has a 4.03" bore and a 3.875" stroke. Which makes it a 395.4 cubic inch engine. Commonly referred to as a 396... You intrerested in buying or are you just a historian?
lildev_wal, The engine is being pulled today, I'll see what shipping will be roughly. thanks.
colton_carlson
Mar 8, 2019 12:21 PM
