[WI] LS1/ LS2/ LS3 Parts
Car: 85 Trans Am
Engine: 350: cam, aluminum heads, etc
Transmission: WC 5 speed
Axle/Gears: Dana 44, 373
LS1/ LS2/ LS3 Parts
I have the following LS engine parts avaiable. Everything is in Appleton, WI and the parts where removed from a running LS2 in my 05 GTO or a new LS3 crate engine. I dropped a LS3 crate engine in so I no longer need these:
LS2 short block assembly: complete and unmolested, includes front & rear engine covers, valley cover, balancer, & sensors, around 5K miles $1950.00
LS2 243 cylinder heads: Complete with valves and new factory springs -- SOLD
LS2 ported intake manifold: Completely ported and a great upgrade -- SOLD
LS3 factory water pump: brand new, take off a crate engine prior to engine swap, never used $150.00
Comp custom camshaft: .621/ .615 lift, 242/ 248 duration, 111 lobe sep, made great power!!! Complete w/ 3 bolt sprocket $150.00
Stock LS3 camshaft, new and never used!! Complete with single bolt sprocket $150.00
LS2/ LS3 electronic throttle body: 2 available - 1 brand new in the box and the other off a used LS2 engine. Used: $75.00 New $150.00
Brand new LS oil pump, $75
LS roller lifters and new push rods: $50.00
LS coil packs: -- SOLD
LS2 fuel rails & injectors: -- SOLD
Or make an offer on everything. Thanks!
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
classified, drivetrain, engine, forum, heads, intake, ls, ls1, ls2, ls3, parts, performance, sale, shortblocks, wisconsin
