[WI] chevy vortec 5.3 longblock with intake $225
Old Jan 12, 2011 | 08:25 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
Have a chevy 5.3 long block ran great when pulled has 130,000 miles. The long block is complete but no oil pan tray or pump pick all rockers are there and push rods, Exhaust manifolds, water pump. comes with complete intake to all injectors and throttle body and fuel rail. has stock cam in it. Has arp rod bolts. all cylinders look good and pistons. the heads are off for inspection. Would be great for budget build or whatever you want to do with it.
Located in southern WI
$225 gets it all. would Trade for sbc forged crankshaft or blocks or other sb parts.
Old Feb 3, 2011 | 02:56 PM
Car: 84
Re: chevy vortec 5.3 longblock with intake $225
wow no taker's for 225.. this is a solid bottom end with heads and intake and many other parts.
Old Feb 4, 2011 | 09:59 AM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Which intake is on it? For TBI GMPP with EGR? If so, would you part that?
Old Feb 7, 2011 | 05:01 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
the 5.3's are almost becoming obsolete to the 6.0 LQ4's and LQ9's. I picked a 2002 LQ4 up for 400 dollars and it has 78k miles on it, thats including harness and all.
Old Feb 7, 2011 | 10:13 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
if you were closer id be all over this.
Old Feb 8, 2011 | 11:52 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Yeah....me too!! I'm phasing out all my Gen I small block stuff and I have enough high end small block parts that I know we could make a fair deal.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
jharrison5
Aug 19, 2015 05:53 PM
