[CT] Single turbo manifolds
Old Jan 26, 2011 | 07:39 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Up for sale is a set of single turbo manifolds for thirdgens. The passenger header uses the same design as BBS but is an unknown brand. Theyre made of stainless steel and the slip fit connection has been replaced with a v band connection which will need the clamp as it broke. The turbo mounts on the passenger side up by the AC. The turbo flange is for a T4 housing. I have not installed these so I may not be able to answer many questions. I just bought them but decided not to go turbo so theyre up for sale. 240 shipped
The passenger rear header primary tube was modified to help clear the spark plugs. It has some surface rust around there as it seems to be steel. It should just sand right off.
Old Jan 27, 2011 | 04:53 PM
Engine: LO3
Re: Single turbo manifolds
bump
Old Feb 22, 2011 | 08:03 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Is this still for sale?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
