[CA] NEW AFR HEADED 355 ROLLER MOTOR COMPLETE
Old Feb 21, 2011 | 01:04 PM
FASTASSBIRD's Avatar
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
Ok first I apologize for the caps, copied this from an old ad and I type in all caps for ease and for work. Also emailing me at RAIIITA@YAHOO.COM or text/call is the best way to get ahold of me as I do not get on here very often since i sold most my third gen's. This motor is basically complete with the exception of rockers. I have a carb intake, a tpi setup or a holly projection to top it off. Headers are hooker headers designed for the third gen f bodies. distributer is also for third gen remote coils. Any other questions please email/text/call and ask. I will ship, or drive it some distance as long as my gas is covered. Here is the ad I posted on Craigslist:
SOLD ALL MY CAMAROS, SO DONT REALLY NEED THIS ANYMORE, SEEMS LIKE OVERKILL FOR MY CHEVY TRUCK. FACTORY 4 BOLT MAIN FACTORY ROLLER CAM BLOCK PUNCHED OUT .30 OVER BY DAVE HIATT AND COMPLETLY ASSEMBLED BY DAVE (COMES WITH RECIEPT) AS STATED BEFORE FACTORY 4 BOLT MAIN BLOCK OVER THE COUNTER FACTORY ROLLER CAM BLOCK WITH NEW ZZ4 CAM ROLLER LIFTERS SPIDER AND RETAINERS. BILLET ALUMINIM TIMING CHAIN COVER OVER A NEW DOUBLE ROLLER CHAIN. ONE PIECE REAR MAIN SEAL SO COMES WITH A ONE PIECE COMPOSITE PAN GASKET SO NO OIL LEAKS! NOW TO THE FUN STUFF! AFR 195 CC HEADS BOLTED ON TOP USING ARP HEAD STUDS THESE ARE BRAND NEW AND HAVE NEVER BEEN RUN! THEY COME COMPLETE WITH THE HYDRA REV KIT AND OVER SIZED VALVE SPRINGS FOR CAMS RATED TO .700 LIFT! NOW THATS A NASTY CAM! THEY FEATURE BOTH VALVE COVER PATTERNS SO YOU CAN RUN OLD SCHOOL COVERS OR NEWER CENTERBOLT VALVE COVERS (CENTERBOLT COVERS INCLUDED). PUSH ROD GUIDE PLATES ARE ALSO INCLUDED. ALSO INCLUDED IS A SET OF HOOKER HEADERS, NEW HARMONIC BALANCER MSD PRO BILLET DISTRIBUTER, EDELBROCK PERFORMER INTAKE AND EITHER A DEMON 650 CARB (USED BUT FUNCTIONAL) OR I EVEN HAVE A HOLLY PROJECTION SET UP I CAN TOSS IN. I HAVE RECEIPTS FOR MOST OF THE PARTS AND MACHINE WORK AND WILL BE INCLUDED. THE ONLY THING THIS MOTOR NEEDS IS ROLLER ROCKERS TO BE FINISHED! GREAT FOR A ENGINELESS CAMARO CHEVELLE IMPALA NOVA OR EVEN A C-10 TRUCK. CASH TALKS I HAVE WELL OVER 5K IN THIS SET UP WITH THE HEADS AND EXTRA PARTS! THANKS FOR TAKING THE TIME TO READ THIS
559-321-4096
Price: 3500 FOR EVERYTHING SEPT THE GAS TO RUN IT
Old Feb 23, 2011 | 11:07 AM
Re: NEW AFR HEADED 355 ROLLER MOTOR COMPLETE
No interest in this at all?
Old Feb 23, 2011 | 01:16 PM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
A few questions
forged or cast crank (steel or iron)
Info on rods and bolts
piston info including compression ratio
Price without headers, distributor and no intake or carb etc
Old Feb 23, 2011 | 02:52 PM
steel crank, forged pistons, stock rods with arp bolts recondtioned when built. I would prefer to sell as a whole, once this is gone i have no use for chevy based parts. but if I were to sell as a long block would take 2850
Old Feb 23, 2011 | 02:53 PM
oh if memory serves me correct compression was 9.5 to 1 with these heads
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
KO1
Aug 31, 2015 06:31 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
