[FL] 86 LB9 Partout; TPI Setup & Aluminum L98 Heads
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
Tearing apart my 305 LB9 and wont need the TPI setup or heads anymore.
- TPI setup; SOLD
- Ported/siamesed Plenum
- Runners (1 tiny dent)
- Ported Lower Base
- Fuel Rail w/injectors
- Throttle Body w/Air Foil
- Distributor, Cap, and Rotor
Pics: http://s197.photobucket.com/albums/a...s/TPI%20Setup/
- Stock Single Fan w/motor $40 Shipped
- Aluminum L98 Heads; these are the 113 castings with D-shaped exhaust ports. Heads come with the rocker arms, guide plates, pushrods, and ARP bolts I used. One intake manifold bolt hole may be stripped.SOLD
Pics: http://s197.photobucket.com/albums/a...20L98%20Heads/
- Stock 700R4 Driveshaft
- TPI Snorkle w/lower Filter Assembly & MAF SOLD
Extra TPI Stuff;
- Plenum: In the process of being polished, I stopped sanding at 320grit. $55 Shipped
- TPI Runners w/Cold-start: Kinda beat up. $40 Shipped
- TPI Snorkel SOLD
Also selling a set of "Dyno Don" 1 3/4 Headers with Ypipe. $SOLD
- TPI setup; SOLD
- Ported Lower Base
Extra TPI Stuff;
- TPI Snorkel SOLD
Car: 86 IROC-Z
Engine: 370 LQ9
Re: 86 LB9 Partout; TPI Setup & Aluminum L98 Heads
Pm's replied to, pics will be up tomorrow.
Car: 86 IROC-Z
Engine: 370 LQ9
Car: 86 IROC-Z
Engine: 370 LQ9
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
might be interested in the heads... can you confirm if that bolt hole is stripped or not? also are the springs still stock on them or upgraded? do they need a rebuild, such as valve seals? thanks
Car: 86 IROC-Z
Engine: 370 LQ9
Will have a look at the threads tomorrow. Was told by the previous owner that the springs are Eglin capable of .580 of lift, but they look like stock springs to me. Heads got a valve job, with new seals, locks, etc before I installed them back in 07.
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
too bad, i am searching for a stock throttle body for my 86 TPI 305. # 865-256-8250
Car: 86 IROC-Z
Engine: 370 LQ9
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
