Rear DISC BRAKE SETUP FOR BW 9-BOLT PBR CALIPERS COMPLETE $100
Old Mar 14, 2011 | 11:55 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
UP for sale is a complete rear disc brake set-up for f-bodies. This comes with the backing plates for the BORG WARNER 9-BOLT rear end. This setup is the later 89-92 version with the aluminum PBR calipers and 12" rotors. Included are both calipers and brackets, parking brake cables, two NEW raybestos rotors (have surface rust from storage but have never actually been used), a set of new Raybestos brake pads, an NIB rebuilt Raybestos master cylinder, and the backing plates and the steel brake lines. The backing plates alone are a rare score since '89 was the last year of the 9-Bolt axles and the first of the newer and better rear disc setup. If you've got an earlier F-body with a 9-bolt and the earlier disc setup or drums and you've been wanting to do this upgrade, this is a chance opportunity to get it done. These parts are bulky and heavy and I will not even attempt to ship them. PICK-UP only. I am located in the Bay Area in California. I am trying to get rid of this stuff so i've priced it accordingly but that price is firm. Some parts are not pictured because of the attachment limit.
Attached Thumbnails Rear DISC BRAKE SETUP FOR BW 9-BOLT PBR CALIPERS COMPLETE 0-9boltdiscbrakes-003.jpg   Rear DISC BRAKE SETUP FOR BW 9-BOLT PBR CALIPERS COMPLETE 0-9boltdiscbrakes-006.jpg   Rear DISC BRAKE SETUP FOR BW 9-BOLT PBR CALIPERS COMPLETE 0-9boltdiscbrakes-004.jpg
Old Mar 15, 2011 | 07:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear DISC BRAKE SETUP FOR BW 9-BOLT PBR CALIPERS COMPLETE $100
Bump for a bargain.
JamesC
Old Mar 15, 2011 | 08:02 AM
Twin_Turbo's Avatar
I'd take it but have no way to pick it up
Old Mar 16, 2011 | 09:18 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
PM sent
Old Mar 16, 2011 | 11:09 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Will these bolt up to my camaro rear end its a drum but its not a borg warner
Old Mar 16, 2011 | 03:13 PM
stealthram92z's Avatar
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
how much shipped to 54627 ettrick Wi
Old Mar 19, 2011 | 01:45 AM
SickRS,
This set-up should work with your rear end BUT you will need to obtain the correct backing plates for the 10-bolt. Those should be easier to obtain and you might even be able to get them from GM still but I don't know. Also, since you already have a drum brake master cylinder, you will NOT need to change that out.
Stealthram92z,
I am not really trying to ship these items as they are heavy and bulky.
Old Mar 19, 2011 | 09:49 AM
do you have paypal, if so I'm ready to pay if you decide to ship them. thanks Les
Old Mar 19, 2011 | 02:07 PM
cliffcamaro1982's Avatar
Want a title? Post!
Car: 1982 Z28
Engine: 400 - vortec heads roller cam
Transmission: 700 R4
Hello,
Would you consider shipping via mail to me in Canada, without the rotors (the heaviest parts).
Thanks.
Cliff
Old Mar 26, 2012 | 12:20 PM
Rayss396's Avatar
Car: 1986 Monte SS 383, 70 SS396 conv.
Engine: 396
Transmission: th400
Axle/Gears: 3:42
Sent a email.
Old Mar 26, 2012 | 03:21 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
PM sent
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
