another mini ram intake 1150 shipped
Old May 21, 2011 | 09:06 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Im selling a TPIS mini ram intake that came off a corvette.... this intake is slighty used and is in excellent condition..... This intake has been praised as the ultimate fuel injection setup for the SBC.... this intake comes with the intake itself, throttle and cruise control bracket, waterneck housing the matching fuel rails and adjustable fuel regualtor and 58mm 1000cfm bbk Throttlebody.. you WILL NOT be disappointed with this intake.. this is just simply a masterpiece intake.. nice semi polished fuel rails and regulator and semi polished engraved tpis logo on each sides of the manifold makes it a work of art.. nice looking throttle body on this manifold to take advantage of the intakes 6500+ range.. if you want a intake that can pull to 6500+ rpms then this is the intake for you... so give your built 355 or air hungry 383 a nice flowing intake that will be up to the task..... im selling this as a complete kit... this setup retails close to 1800 new.. im asking a buy it now price of 1150 dollars plus shipping... this is a excellent price for this near complete intake..... if you have any questions please e mail me or text me at 919 906 1401.... this intake needs a new home.....
this is direct from TPIS website.......
The TPI style intake works excellent at creating a large amount of torque at low RPM, but rapidly drops off as the revs rise. The TPiS MiniRam produces an ultra flat torque curve and builds incredible amounts of horsepower, pulling strong to 7500 RPM through it's specifically designed plenum and runners. The MiniRam can deliver as much as 80hp or more over a stock TPI intake, depending on the engine combination. It is also a great and simple way to convert any small block Chevy to fuel injection. The MiniRam's one piece design makes for a clean, uncluttered installation that is easy to work on while eliminating the possibility of vacuum leaks that multi-piece manifolds tend to experience. Sitting 2" shorter than a TPI system the MiniRam has plenty of hood clearance and is a perfect choice for a hot rod application. Intake comes with throttle brackets, waterneck
i measured the ports with my dialing caliper and the ports measure about 1.23 Wide x 1.99 Tall which on felpro's site indicates its the 1204 version....... i hope this helps....
vortec heads have 8 bolts on the manifold... this has 12 which is for the standard sbc heads..
Old May 21, 2011 | 12:04 PM
88fastgta's Avatar
Re: another mini ram intake 1150 shipped
i just need enough money to buy my first fuel injection tpi intake..... which is 1050 dollars... i want the best stock look and that first tpi is my best bet... otherwise if i wanted all out performance i would just keep my miniram....
Old Jun 8, 2011 | 09:47 PM
Cadmaro's Avatar
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
Still have this intake?
Old Jun 9, 2011 | 10:38 PM
88fastgta's Avatar
sorry man i sold this about two weeks ago on ebay....
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
89mulletbird
Aug 12, 2015 07:08 PM
bryan623
Aug 10, 2015 11:33 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
