[AL] WRECKED 2000 PONTIAC TRANS AM - DONOR CAR for LS1 SWAP SOLD!!
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
I have a wrecked 2000 Pontiac Trans Am that is ready to be used a a donor for a LS1 swap. Its an automatic car with roughly 107K miles on it. The car was hit hard in the front drivers side corner by a car that ran a stop sign. The engine is ALL STOCK. I have stripped the car down with the exception of the running gear and associated electronics. Before being asked, its intended to be used as a donor car for a LS1 swap and is not reparable!!! There is no interior in the car, no good body parts (except the doors) and no brakes. What is there is the complete LS1 engine, transmission, rear end (no brakes or backing plates) and wiringing...including the wiring harness, computer and fuel pump. Basicaly everything you need to put a LS1 in your car. The AC compressor is there and was holding a charge when I cut the front end off. The only damage the engine recieved in the wreck was the radiator hit the plastic power steering pump and busted in...I do have a replacment pulley if I can find it. If not they are like $35 for the pulley. I have no way of cranking the car since there is no cooling or electrical system in the car....we can turn the engine by hand at the crank but I cant crank it for you.
I am asking $1850 OBO for it and if you have been thinking of a LS1 swap you know what a deal this is on a complete running gear and wiring!!!
Call or text me at 229-894-0165 with any questions. The car is located in ATHENS, AL...just outside of HUNTSVILLE.
Pic of the car after being hit:
This is how it is now and whats left:
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: WRECKED 2000 PONTIAC TRANS AM - DONOR CAR for LS1 SWAP
Wish you were closer....I'd take a bunch of things off that motor if you were willing to part it.
I am not going to part this one out...its a perfectly good running fairly low mile motor. But I do have some others I have parted out...pm me what you need.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
DAM id be all over the car if you lived closer and shipping it to Canada would be pretty costly
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Trade for a set of RONAL R15 firehawk wheels? Damn this is a good deal.
Car is sold...guy came and got it this afternoon!
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
