10 or 9 Bolt Posi Heavy Duty 1982-1992 Camaro / Firebird Rear End.
Old Jun 3, 2011 | 02:20 PM
Doms Camaro's Avatar
Want a title? Post!
Car: 1985 Camaro IROC Z28
Engine: Built Roller 400 with spray
Transmission: Mad Dog Stage 3 700R4
Axle/Gears: BW 9 bolt Disc Brake 3.90 Ratio
Hey guys hows it going?
I have recently gotten into the business of rebuilding and restoring camaro and Firebird rear ends. I have a bunch to choose from and can do almost any ratio u need. You wont find a better quality job any where else. I guarantee that.
If you are interested in a good looking quality rear end. Then I have put a little write up together for my 10 bolts, and have something similar for the 9 bolts as well. Thanks For looking. I can also ship these in U.S. or Canada
10 Bolt Posi Heavy Duty 1982-1992 Camaro / Firebird Rear End.
Professionally rebuilt and restored rear end. Rated at 375 Horse Power.
List Price $1550.00 here is what you are getting for your money.
1982-1992 Camaro / Firebird performance rear end.
Rear end has been disassembled, cleaned, inspected, sand blasted, and painted with flat black chassis paint.
All bearings, races and seals have been replaced with top of the line Timken brand parts.
28 spline heavy duty Chromemoly axles. With new 12MM press in lug studs.
O.E. 3.73 gears. Low mileage used. Perfect ratio for street strip performance. NO 500 mile break in period needed, as required with new aftermarket gears. O.E. gears are very strong. In addition, they are very quiet, unlike cheap, noisy aftermarket gears.
Brand new Auburn HP Series differential part number 542040. Manufacturer provides a 1-year warranty and 4-years of replacement exchange coverage.
No crush sleeves or main cap bolts. This unit has been upgraded to a Ratech solid pinion spacer, and ARP main cap stud kit. This is done for higher horsepower handling capabilities and better reliability.
Aluminum differential support cover. This supports and prevents the bearing caps from breaking under high horsepower acceleration.
No brake drums or brake hardware included. You will have to use all your own brake hardware. Rear end does include brake backing plates. We can include brakes, ask about pricing.
We can also build combinations with the following ratios 2.73, 3.08, 3.23, 3.42, 3.73, 4.10, 4.30 and 4.56 to handle up to 375 hp. in one of our nicely restored and rebuilt rear end housings. Ask about pricing………
MY PERSONAL GUARANTEE! This unit contains all parts as specified, and all parts and clearances are correct and are in good working condition. These units are intended for performance street use only. I offer a 30 day money back guarantee if you are not 100 percent satisfied with the quality of this unit. Refund does not include shipping costs.
Call Dom 678-997-9299
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
