Parting out IROC's (Multiple) I have more than one
I have pretty much every part. I am moving and need to get rid of my iroc parts. Let me know what you need and what you have to offer. Trust me you don't want me to start the price as I have a tendency to be high. Here are just a few things I have:
- Ttops
- Hood Louvers (not rear)
- Ground effects
- Ttop bags
- weather stripping (NIB)
- 90 style rims and center caps
- TPI units (86, 87, 90)
- Wiring harnesses
- ECM's
- Plastics galore
- Rear hatch motors
- New rear hatch shocks
- some convertible parts
- etc
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Parting out IROC's (Multiple) I have more than one
Wouldn't happen to have rear hatch louver hardware would you?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Do you have the aujp memcal from the 90-92 ecm?
Car: 85 Camaro Z28
Engine: 5.7 TPI
Have a TPI Distributor Cover?..... metal or plastic plenum extention piece....
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Im lookin for the tpi distributor cover with the screws if you have the metal one that would be great but if you only have the plastic one its all good and final price with shipping to lancaster, ca 93535
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Do you have any outer window sweeps? Need both left and right outer sweeps. Also need 2 black iroc center caps
I am sure I have some of the sweeps not sure what condition they are on. I am selling my center caps (90's) as a set they are the silver style and smaller than the 87 style.
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
how much for a harness(auto) and computer and shiping to V0N 2P0??
ohh and i need some other random parts off the tpi too the brackit on the side with both cables and 350 injectors an fuel pump !
thanks tristan
thanks tristan
Make me an offer. Like I said you don't want me to start the process because I am high!!! I would have to look for the random TPI brackets as I am trying to sell my TPI's complete. No 350 parts. I do have a fuel pump but it was from a 305 not sure if they are the same. I only charge actual shipping so all prices are excluding shipping and once you agree to the price I will calculate shipping (will send receipt) from 98092.
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Iroc wheel center caps
$40 shipped? (if they are in fair condition, don't need to be perfect.)
I also need the black lug nut covers if you could throw those in the deal.
Also, shot in the dark. you don't have a t-top headliner do you?
I have one gray new headliner I might be willing to part with. I am looking to move to black so for the right price I may sell it. As for the center caps they are in "fair" condition and would sell them for $60 shipped but I would throw in a handful of black lug nut caps that I have.
I have one metal and one plastic. I don't have the screws. The one plastic one has one hole that has been pushed through if that makes sense. Make an offer I only charge actual shipping (with receipt to prove it).
Can you send pics of the t-top bag to tonyluker@hotmail.com......are the straps still good?
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
How much for the rear hatch shocks and hatch motor?
Car: 1986 Iroc z
Engine: 350 tpi
Do you have the Hood louvers available? DO they have any broken tabs on the back? How much shipped to saint cloud florida. 34773? Thanks
I have two sets. One with some broken tabs and one without any. $60 shipped for the broken tabs. $100 for the one without any broken tabs.
Car: 1989 Camaro RS
Engine: V6 2.8l
Transmission: Automatic
how much for your hatch shocks and top dash and a driver seat?
and how much to ship to 95206
I only charge actual shipping from 98092 I don't have time to look up shipping for everyone that request a part (Will show receipt to prove it). Make an offer on the parts. If it's worth my time I will remove and ship.
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Looking for
- upper plastic radiator bracket with the upper hose support. I have a dual fan setup.
- black garmet hooks
- do your cars have the split seat backs or 1 piece? looking for drivers side bracket (spot welded to car) and stud for a split back seat.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
What is the 90 ecm a 1227730? does it include a chip and if so what re the 4 letters on it? And how much did you want for it?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I don't know as any of the letters on the outside of ECM are not readable. I have multiple ECM's and one came out of the 90 convertible. I have no way to tell the difference between them unless someone can help me find numbers that make sense somewhere else on the ECM's.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Do you have a 5-speed inspection cover?
I also need a good set of outer window sweeps if you got em.
$65 shipped??? to 71047
thanks, Greg
thanks, Greg
Car: 1987 Iroc Z
do you have a 5-speed inspection cover?
Engine: Stock 350
Transmission: 5 spd
Do you still have the rear hatch pull down motor and the large plastic piece that covers it? What color is the plastics?
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Do you have the 700R4 auto transmission fluid lines to the trans cooler (metal)?
Offer $15 plus I'll pay for shipping.
Where are you located?
Phil
Tucson, AZ
Phil
Tucson, AZ
Car: 1997 z28
Engine: lt1
Transmission: t56
any of those irocs carbed? if so, i really need a choke lever and attatching screw, can pm more detailed info if you do thanks
