Heads, Intakes, Flywheel, Smog Pump, Tailshafts, Valve Covers, Starter, Water Pump
SubscribeSup,
Have these parts around. Want to get rid of them ASAP so lemme know.
Make an offer on any part. Only willing to ship smaller stuff. Heavier stuff is best left for local pickup in NYC. Would be willing to let go of parts free pending on situation and where you are.
416 Heads- Will need cleaning up and resurfacing. Planned to use these to bump compression on my smogger 350, but didn't. Reseal the valves.
86 Stock GM Spreadbore Intake- Sandblast these to make em nice.
Edelbrock Streetmaster Single Plane Spreadbore Dual Bolt Pattern Intake
Valve Covers- Off the same 86, will need nice cleaning
Straight Bolt Pattern Starter- Was new a year ago $50
SBC Water Pump- Long neck style? Look at pic, make offer$
SBC Flywheel
SBC Flywheel
700r4 Crossmember- Was welded on the side, can be hammered straight
Smog Pump off my 83
Rear 4th Gen Stock DeCarbon Struts
Chrome Carb Cover- Smaller one
700r4 Tailshaft- Electronic Speedo with red gear
700r4 Tailshaft- B&M I think, doesn't have torque arm hole, electronic speedo?, no gear
If no one takes this stuff, it is going in the garbage. Summer cleanup.
Smog Pump off my 83
Is the starter a T5 starter and will you just sell the end housing - the part that bolts to the engine? Thanks.
It was on my 700r4. Not sure on compatibility, never had a T5. Trying to sell as a whole atm, gotta get this stuff moving.
700r4 Tailshaft- Electronic Speedo with red gear how much ??
PM sent.
