[NY] Earl's 6AN Fuel Filter - Carb
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
http://www.summitracing.com/parts/EAR-230206ERL/
Used, in perfect working order. Only reason removed is I went to larger fuel lines requiring new filters. Used before and after my electric pump, cleaned yearly with zero issues. New they are $37 @ Summit or Jeg's.
SPECS:
Inlet/Outlet Size: -6 AN, Smallest Particle Filtered: 85 microns, Filter Element Material: Stainless steel mesh
Overall Length (in): 3.840 in., Outside Diameter (in): 1.125 in., Maximum Fuel Pressure (psi): 75, Fuel Flow: 4 to 5 gpm (240-300 GPH)
$20 shipped to you.
SPECS:
$20 shipped to you.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
