[MD] Haltech E6GM Plug In ECM
Old Aug 8, 2011 | 05:34 PM
shahee1's Avatar
Want a title? Post!
I have a Plug-In Haltech ECM for sale ... I bought this years ago for a project that never got off the ground and never had the chance to install it in the intended vehicle. I has not been Installed or programmed ... I have the software for it and the program cable ... I will also give you the install and setup manual. Asking $400. OBO ... This unit will work with just about any DELCO ECU and will run just about any cylinder engine up to 12 cylinders and rpm limit of 16,000rpm ...
Two plug Setup
Pinout follows -
PLUG 1
A1 - PUMP RELAY B1 - N/C
A2 - N/C B2 - N/C
A3 - N/C B3 - CRANK SENSOR GND
A4 - N/C B4 - N/C
A5 - N/C B5 - CRANK SENSOR SIGNAL
A6 - +13.8V SWITCHED B6 - N/C
A7 - TCC B7 - N/C
A8 - N/C B8 - A/C REQUEST SWITCH
A9 - N/C B9 - N/C
A10 - ROAD SPEED B10 - N/C
A11 - MAP+ATS GND B11 - N/C
A12 - GND B12 - N/C
C1 - THFAN CONTROL D1 - GND
C2 - A/C CONTROL D2 - TPS / CTS GND
C3 - IDLE 2 D3 - GND
C4 - IDLE 1 D4 - EST OUTPUT
C5 - IDLE 3 D5 - BYPASS CONTROL
C6 - IDLE 4 D6 - O2 SENSOR GND
C7 - 4TH GEAR (AUTO) D7 - O2 SENSOR SIGNAL
C8 - N/C D8 - N/C
C9 - N/C D9 - N/C
C10 - COOLANT SIGNAL D10 - GND
C11 - MAP SIGNAL D11 - N/C
C12 - AIR TEMP SIGNAL D12 - N/C
C13 - THROTTLE SIGNAL D13 - N/C
C14 - +5V (MAP / TPS) D14 - N/C
C15 - N/C D15 - INJECTOR CONTROL 1
C16 - N/C D16 - INJECTOR CONTROL 2
PLUG 2
A1 - RX B1 - GND
A2 - TX B2 - N/C
A3 - IGNITION TRIM SIG B3 - GND
A4 - +5V (TRIM) B4 - N/C
A5 - +5V (TRIM) B5 - GND
A6 - FUEL TRIM B6 - N/C
Haltech website has info for all prior products.
email: thomase1_99@yahoo.com
txt: 202-306-1811
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
